Suspension down, many warnings in instrument cluster. What broke?
2006 LR3 V8, 122,000 miles.
Bought used Jan 2013 with about 70,000 miles on it. Been a trooper until now.
While driving the last 10 miles of a 250-mile run...
Suspension went to lowest setting
Screen showed hill descent control fault and transmission fault
Amber word BRAKE appeared in fuel-quantity/engine-coolant dial cluster
Dealer wants to look at it -- says it could be anything, and is not a "yeah, we see those all the time" problem. Says it could even be as simple as a faulty switch on the brake pedal.
Attempts to lift the suspension to normal driving height are blocked because of the faults annunciated.
Is the car driveable the 250 miles back home in this condition at a stately pace?
Educated guesses on what could be causing this are invited and much appreciated!
Great vehicle for hauling boat, trailer and two big Bernese in all weather, but misbehavior like this has me concerned. Thanks for any help.
I have this problem
Can be brake lite build or switch, can be the off road selector, abs module, abs sensor, suspension height sensor, wiring issue
Unfortunately you need someone to look at it that knows what to do
You cannot drive it if the transmission disabled is on, it will not shift you could blow the engine
I am guessing speedometers not working, keep rpm under 3 that's what I tell my wife so she can limp home
Ours was reset and not come back so no idea our actual problem yet
M5Z3M (12-01-2014)
Thanks, Tom R
The problem fixed itself overnight but recurred after 10 miles this morning. On both occasions, this failure lit the DSC amber warning, the transmission amber warning and the word BRAKE in the fuel-gauge/temp cluster. Although the suspension dropped to its lowest setting and would not raise, the transmission continued to shift and the speedo and tach both worked, leading me to feel confident I could drive it 250 miles at a slow pace to spare the largely ineffective suspension from too much abuse. Knowing that the transmission still shifts and the speedo and tach still work, do you continue to regard a 250-mile gentle drive (40 mph max) as inadvisable?
You mentioned that your vehicle was "reset" and has worked since. Were any of the suspect components that you listed replaced, or was it just a reset?
Thanks again for your thoughts.
What I would try, as a limp home emergency only, the next time it "Magically Reset Itself", pull the under the hood fuse - F26. Hopefully, when the computer thinks something is wrong, it won't be able to drop the truck. You'll still get all of the warnings, but hopefully able to drive it without it going to the stops. Good Luck!!
M5Z3M (12-01-2014)
Ours had majic reset at first then returned, I did bulbs and brake switch , but still returned, had a dealer tech friend reset everything, he suspects from the codes it is abs module or the off road selector
Stated the off road select and shifter are very sensitive to spills
My sunroof leaked on them for god knows how long before my purchase of the vehicle so for now we wait till it comes back before he delves deeper into it, basicly though, anything can set these off
Mine had most every lite on dash lit and stated on dash; trans limited gears, suspension disabled, park brake disabled/ fault, special programs disabled, couple of lites were even flashing
Had no hi gears in trans, had no speedo, suspension was dropped
If your transmission is working correctly should be OK IMO,
M5Z3M (12-01-2014)
M5Z3M (12-01-2014)
If you sneeze in the wrong direction during the 3/4 moon phase with the sun slightly out of alignment with mars and are not listening to monks chanting it will also cause it
Lol. But seriously seems like almost anything can cause it there is no 1 fix, knowing codes tripped helps diagnose but only a little
M5Z3M (12-01-2014)
Made the 250-mile drive north uneventfully yesterday after letting the EAS compressor raise the suspension, pulling fuse F26 and keeping the speed down to 50 the whole way. (Gas mileage went from the usual 18-point-something to 23.2.)
Vehicle is now with my local indie mechanic, who has worked on various LRs and RRs and says he has "ways of making these cars talk." So we'll see.
Thanks to all for your suggestions. I'll let you know if, by magic, my guy finds one bullet to blame.
riko suave
03-18-2009 04:34 PM
CandiMan
10-30-2008 01:39 AM
Greg
08-08-2007 04:47 AM
