Suspension drop
Old Jun 6, 2020 | 10:01 AM
Philip Chan's Avatar
Default Suspension drop
Just confirming here. I would come out and the car would be at access height. Usually after a day or so.
since I’ve been working on this leak, I left the doors open. Perfect way to disable the auto levelling without pulling the fuse.
the front end - both sides has dropped.
does this mean the suspension block for the air needs replacement in the front?
just confirming.
Old Jun 6, 2020 | 04:15 PM
houm_wa's Avatar
I don't think the doors open approach is fool-proof. You're better off disconnecting the negative battery terminal. That said, typically yes, without power to the EAS, if both sides in front drop, then it's the front valve block.
WiL2508DaN
Sights N Sounds
Nov 9, 2019 12:08 PM
vnmona
May 2, 2018 10:10 AM
michaelfisk
Apr 25, 2012 07:01 AM
thechidz
Feb 9, 2010 03:28 PM
kitoko
Dec 19, 2008 08:15 AM
