Suspension fault after new compressor
Hi,
I changed the compressor to a new hitachi one, disco still had the factory one i believe.
replaced it because suspension gave faults and basically didn't work. Although after calibration it worked but decided to change the compressor anyway since it I had allready.
now I keep getting a red light for suspension, calibrated a couple times but no success.
any ideas on where to look? I have a iid tool!
Thanks in advance 😄🤘
You have a gap, so what are the codes? Any? Did the Rover originally have a Hitachi style or was is AMK? Sometimes after playing with the system you can get stuck in built mode or tight tolerance, which will give you a red warning. You can go into gap and go into tight tolerance and back out to see what happens. Of course maybe a connector is not tights. Compressor has two, one being power. Check fuses, relays, etc too.
Hey,
Thanks for the reply.
Was a hitachi style as well. Changed the relay to a new one as well. Compressor turns on so guessing power and all is good. Code "control module - system programming failure - deactivated (ab)"
connectors clicked when plugging it in, can try cleaning them maybe.
Thanks!
Nah, prob not connector issue if it is powering up. I would try the tight tolerance trick. Or you do in fact have a bad calibration for some reason, which could be due to a faulty height sensor. Is this a cheap Hitachi knock-off by chance?
Yeah I'll defintily try the trick. can a sensor break after fitting new compressor? Worked before after calibration 🤔.
not cheap at all hehe the real deal expensive compressor 😅👍.
maybe parking it up in a different. Just realised it's standing a bit higher on the front cause of the driveway.. might mess with it?
I doubt your broke a sensor.
Genuine Hitachi are $300 USD, so I hope you did not pay too much!
As long as the ground is flat, it should not matter.
At this point I am still guessing you are in build mode, tight tolerance mode or have a corrupt calibration.
Hi!
The light is off now, its sitting at normal height but doesn't go up or down. No faults read. Just ping when I hitnup or down.
getting there haha
The relays are all the same. As discussed, a new relay is provided out of caution not our of need. A compressor is high amp and one that dies can damage the relay by pulling way too much juice though it. And a damaged relay can cause issues. So out of caution, LR recommends a new relay with a new compressor because nothing would be worse than leaving the dealer with a new compressor just to have some other issues. The relays themselves are all identical and the same used in other systems, like with the fuel pump.
Exactly, I changed the relay with the supplied relay. Problem is now that I get a orange light and the display says " suspension lowered" .. I can hear the compressor kick in. Tried to calibrate over 6 times by now, no difference, Next step will be looking for leaks but don't think I damaged any lines and all seem to be in pretty firm. Strange thing, orange light is on but iiD doesn't read any suspension fault..
