Suspension Fault C1130-66. Front EAS valve block rebuild kit
Like so many before me, the front EAS valve block is acting up. Settling over the night, compressor coming on occasionally for no reason. After I lifted it to off road height and pulled F26 from the engine compartment fuseblock, I found the truck flat on its nose the next morning.
Here’s the code the truck threw:
Suspension
- C1130-66 (2E) Air spring air supply - Algorithm based failure - signal has too many transitions/events
I still have to do my rear block, but its not leaking noticeably. Before you do this, I recommend a compressor dryer rebuild first. Then operate on the new dryer for a at least a week to get some of the particulates out of the lines. Otherwise it will just get contaminated in short order and the block will again leak.
