Suspension Front Wheels on Bump Stops (no codes)
Old Jul 31, 2016 | 02:45 AM
wallop85's Avatar
3rd Gear
Default Suspension Front Wheels on Bump Stops (no codes)
New here after many suspension problems lately.
2006 LR3 SE 4.4
Replaced failed compressor and relay today (brand new) and it raises the rear wheels, but the front two wheels are sitting on the bump stops. There are NO fault codes and no warning lights. And now I am beyond confused. I have not seen this exact issue on any forums or online.
Sprayed for leaks and did not find any.
*To note: the previous failed compressor had fault code of "pressure does not decrease when venting gallery" and "computer module." The LR Dealer also cleared the problem with the car and described that somehow the LR3 put/locked itself into transportation mode. This turned the red warning light to the amber light.
Have any of you come across this issue or have any ideas? Supposed to be moving across country and need this fixed ASAP.
Old Aug 1, 2016 | 04:32 PM
Zelatore's Avatar
First, do you have Nav? If so, when looking at the 4x4 info screen does it show the front wheels as being out of range or in normal position?
Second, do you have a GAP iiD tool or similar that you can use to manually control and read each corner?
With both, you're trying to see if the computer thinks the front is at normal ride height - if it does that's why it's not moving and I'd be looking at sensors. I'm guessing the truck doesn't think it's out of range or you'd have an error on the dash and you say that's not the case.
If you have the GAP or similar, try to manually raise the front using it while monitoring the height reported by the sensors. You should see it moving in the data stream. Again, if the truck physically moves but the data doesn't change you know to look into height sensors.
Can you tell I'm a fan of the GAP iiD tool?
Old Aug 8, 2016 | 08:04 PM
wallop85's Avatar
3rd Gear
Found a leak in the compressor. And now have compounding issues.
I have pulled the fuse to prevent the compressor from turning on and potentially burning it out, which will be replaced.
There was the amber light when pulling the fuse for obvious reasons. However, it switches from the amber light, to the red with the 30mph warning light. It changes to amber and red whenever it wants to while driving. Now lets talk fault codes. I have noticed even though the fuse is pulled, the car does not have a remembered mode when turning the car on, sometimes it will say Access and others Standard. The car will also say lowering and raising, while driving (although it cannot do that). I have erased these codes, but they continue to keep coming back.
"switch activation too long"
"both switches pressed at the same time"
The 3 Amigos amber lights have been popping up with frequency now as well. In addition, and perhaps unrelated, one of my friends was able to open the rear driver's side passenger door while the car was locked. It sets off the alarm when opened, but the door does not lock.
Any ideas where to go from here? I am getting very nervous driving it across the country now...
Old Aug 9, 2016 | 01:04 AM
houm_wa's Avatar
What are you referring to by the "3 Amigos" fault lights?
Old Aug 9, 2016 | 01:35 AM
wallop85's Avatar
3rd Gear
Suspension, Brake, HDC Transmission Faults
Old Sep 14, 2020 | 03:40 PM
motherlowed's Avatar
Default SOLUTION for Suspension Fault
Hey guys,
So, I took it in to my local Rover shop here in Portland (Columbia Rovers - really good shop) and they ran a diagnosis on it, and it turns out my rear height sensors went bad. This dropped the truck to the bump stops, and basically just shut it down, disabling the compressor and the whole EAS system. As I understand it, I could have potentially cleared this fault if I had a GAP tool, and put it in build mode, and then I'd have to replace AND recalibrate my new rear height sensors in order to fully resolve this issue.
Hope it's helpful to someone else out there.
Old Sep 14, 2020 | 08:21 PM
05TurboS2K's Avatar
Well thank you for following up on here. When folks don't do that, the post has little purpose for others.
Old Sep 14, 2020 | 08:22 PM
05TurboS2K's Avatar
Classic Discovery 2 Terminology haha!
If you own a Discovery 2, you know the 3 amigos and you hate them with all your soul.
Old Sep 14, 2020 | 09:27 PM
houm_wa's Avatar
Hahaha ...I know what the D2 three amigos are, that's why I asked what the OP was talking about.
Old Sep 14, 2020 | 09:28 PM
houm_wa's Avatar
Default Good luck...
...I have a feeling that wasn't the real problem though. Height sensors almost never go bad, let alone two of them at the same time.
Freedom38
Aug 5, 2015 12:50 PM
CANAMDiscovery
Apr 2, 2012 04:20 PM
RROJ
Nov 20, 2010 01:21 PM
roverfun
Jan 3, 2009 04:35 PM
brandon4589
Jan 2, 2009 09:47 PM
