Suspension issue
Old Mar 16, 2026 | 07:33 AM
  #21
David Eubanks's Avatar
Originally Posted by Tōn Lōc
My gut tells me that they were not OEM. I’ve decided to replace them both with OEM. Yes, the air is certainly leaking out from somewhere. LOL. If that still doesn’t fix it then at least I know both fronts are new OEM.
You need these struts. All the aftermarket ones tend leak due to incorrect internal O ring sizes and some are old rebuilt struts. Get the new front valve block and you should be good to go. I'm surprised that your LR3 still had the Hitachi style compressor most were converted over to the AMK style as they all tend to fail after 8 to 10 years.
https://www.roverparts.com/suspensio...uts/RNB501580/
Old Mar 23, 2026 | 08:11 PM
  #22
Tōn Lōc's Avatar
Thanks....Yes, I bought OEM struts that should arrived tomorrow. I'll post an update once installed. Thanks again
Old Mar 28, 2026 | 03:34 PM
  #23
Tōn Lōc's Avatar
Ok, latest update...I replaced both from struts and the front still drops fairly quickly...like it's noticeable within a couple of hours. After testing both of the old front struts there was a pretty decent leak in one of them and the other had a very very VERY minor slow leak in it as well. So they definitely needed to be replaced. But that wasn't the only culprit I have just ordered a new front valve block...I guess if that isn't it then it must be the two front air lines?? Kind of unlikely that BOTH air lines would have cracks/leaks in them. I'm starting to get perplexed!
lighting
Range Rover L322 (3rd Gen)
Apr 5, 2025 09:06 PM
TommyBoi
Mar 15, 2025 10:51 PM
rich.cash
Aug 26, 2024 09:41 PM
jgm1
Aug 5, 2022 06:33 PM
taylorm334
Dec 27, 2013 09:34 PM
