Suspension (not another thread!)...but...
So first off, I have a GAP tool. I've run diagnostics, but am a bit stumped.
Issue:
Suspension "dead" - no air, no response and "suspension fault" removing both raise/lower and special programs. Currently on bump stops.
So far I have:
1) Checked all fuses
2) Switched relay with another
3) Used GAP tool
No change.
With the GAP tool, i was able to verify that the compressor works. As per a post by @DakotaTravler I tried to use to the tool to do a guided calibration. The compressor fired and i could hear the valves clicking, but no inflation.
Also using the tool i was able to test the valves separately. They clicked but again no inflation.
So - i am stumped. There is something along the line that it doesn't like.
Simply throwing the switch in the cabin to raise the truck pings in error...and it also pings when first starting up (and leaving for about a minute) without touching anything....
Suspension errors are: C1A00-1D (2E) Control module - General electrical failure - circuit current out of range. Im wondering if anything may have become compromised in the wiring bundle (splice, etc). that gives feedback to the suspension module?
Issue:
So far I have:
3) Used GAP tool
No change.
I did check the connector around the front horn that was fine.
But… found a post about checking the rear valve block given that error code. There was one, going on three more rubbed wires that I could see. It’s a nasty place to attempt a solder repair. (I can't seem to upload photos right now for some reason, but it's the block connector that plugs into the rear valve)
any hints/ tips for this?
You can use a good crimp and heat shrink connector there if you don't want to solder - a heat gun melt solder and heat shrink connector is another option. But it does look like you'll have to depin at the connector since you don't really have any good wire left at the terminal....
