System Fault Special Programs Unavailable - No Compressor!
Old Feb 5, 2024 | 02:32 PM
JRev's Avatar
Default System Fault Special Programs Unavailable - No Compressor!
Hey Guys -
My car sat for 3 days at the airport under a covered parking garage and the LR was sitting on its bags when I got to it. I knew it was lower than normal and thought it would raise back up when I turned it on, NO LUCK! Also, the compressor didn't turn on.
Things I've tried:
  • Checked the battery voltage, the battery is good, 14.4V when on & 12.7V when disconnected
  • Did a hard reset, disconnected the battery and connected cables together for 10+ mins.
  • Connected the computer to the car and some old and new faults popped up, relevant ones are posted below. I cleared everything and it didn't change anything.
Any and all help is greatly appreciated.
Old Feb 5, 2024 | 03:58 PM
DakotaTravler's Avatar
The first code is the only one that worries me, the others are likely ghost codes from no real faults. Its weird that it is an ABS fault yet you have no dash faults for traction/ABS. Anyway... I think that fault is generated when the height sensors are out of range. Do you have sensor rods installed? Also a GAP tool may be more specific with faults in this instance.
Old Feb 5, 2024 | 04:22 PM
JRev's Avatar
Wow, it looks like I may of deleted my original message that I posted on this thread when I uploaded photos.
My car sat for 3 days at the airport under a covered parking garage and the LR was sitting on its bags. It didn't raise when I started the car, and the compressor didn't turn on.
Things I've tried:
  • Connected the computer to the car and some old and new faults popped up, relevant ones are posted above.
Old Feb 5, 2024 | 04:25 PM
Do you have height sensor rods installed?
Old Feb 5, 2024 | 04:26 PM
JRev's Avatar
I installed the 2.5" Johnson Rods, no problems for weeks with them on.
Old Feb 5, 2024 | 04:28 PM
Okay, that is what I thought. And you would not have issues, normally. But in you pic the truck looks much lower than normal. So now the rods have pushed the sensors out of range. This is why rods are the worst thing to install. Just get two jacks (one at front, one at rear) and jack the vehicle back up into a reasonable height so the sensors can be read again. It will start working.
To prevent this, you need to isolate the leak you have so it does not lower too far and put he sensors out of range again.
Old Feb 5, 2024 | 04:32 PM
JRev's Avatar
Ok thanks so much, Fingers crossed that's it. I'll give this a go today and keep you posted. Thanks so much.
Old Feb 5, 2024 | 06:49 PM
JRev's Avatar
That was it, Thanks so much!
Now to track down the leak haha!
Old Feb 5, 2024 | 07:50 PM
loanrangie's Avatar
Just one of the reasons that an electronic lift is better then rods, get a Gap tool and it can do both diagnostics and lift.
P-Bod
Jul 20, 2025 01:22 AM
inater
May 3, 2023 05:19 PM
N E WHR
May 2, 2021 09:41 PM
LONERANGER7010
Dec 29, 2019 09:30 PM
