System too Lean
Old Aug 5, 2015 | 12:10 PM
Crosbo's Avatar
Over the period of a number of months, I experienced the same intermittent codes. Like most of you, I cleaned, checked and even repaired some very small hairline cracks that I thought may have been vacuum leaks. I also started to avoid the "cheap" gasoline places, choosing to stick with the premium brands. I also sought out the ethanol-free fuels, whenever possible. Each and every time, the CEL would eventually return within the week.
Bottom line, I found the problem...my fuel cap. I was accustomed to replacing it to the point that it clicked, then stopping. Now I make sure to crank it down nice and tight...with 2-3 extra turns, just for good measure. I haven't had the codes in 2-3 months now (knock on wood).
So, a freebie that you may want to give a shot. Good luck!
Old Aug 5, 2015 | 12:28 PM
Charlie_V's Avatar
I'll give that a try. I've come to assume that lean codes are just a fact of life.
Old Aug 5, 2015 | 01:05 PM
june82000's Avatar
Sounds like a vacuum leak to me.
Old Feb 21, 2020 | 10:22 PM
Preston Bernard's Avatar
Default This due to the sensor or fuel pump?
Originally Posted by Alphamale
Unlike a rich mixture where unburnt gas passing into the exhaust can damage the CATs, a lean mix shows that there is to much oxygen. This is unlikely to do much harm, but the system will be trying to compensate and you may experience some rough running, therefore don't plan any long runs until you sort it.
just wondering what the average fix is
Old Aug 15, 2020 | 10:38 PM
05TurboS2K's Avatar
I'm experiencing this too for the last week.
Initially I had "too rich" on both banks, I found the airbox boot was leaking just before the MAF. I cleaned the MAF properly with the proper cleaner and boom it went away.........until it then returned with "too lean" codes. Now I can't get that to end, does it once per drive or so. Very annoying. The gas cap doesn't seal as well as I'd like on this, I replaced it, still doesn't impress me with the seal and I'm still getting the code just the same. I tried a amazon replacement MAF, same routine. I can't seem to find the intake leak if there is one.
I do hear a very slight exhaust leak though, except that's not new but maybe it's just bad enough to cause the issue? Though strange that the timing was after cleaning the MAF and yet a new MAF doesn't fix it.
My only thought at this point is that the exhaust leak was being compensated for by the dirty MAF readings and now by cleaning it, I've removed the buffer. I took a few screenshots of the data logs but I don't know that they'd be all that useful.
Old Aug 16, 2020 | 05:30 PM
Rufflyer's Avatar
When you have tried everything listed here has those have not worked, (and you should try all those first) I would reset adaptive learning on the engine. Several threads on this forum came to that conclusion after every thing else failed.
Jeff
Old Aug 19, 2020 | 10:24 PM
05TurboS2K's Avatar
Jeff
I've been hoping it would learn on it's own....... I wonder if my little $60 dollar scanner can reset the adaptive learning curve.
StillRoven
Mar 6, 2025 09:37 PM
StillRoven
Freelander
Jun 29, 2015 06:08 PM
dmccoig
Apr 5, 2010 11:19 AM
2000 Disco 2 SD7
May 3, 2008 07:10 PM
ToddinLou
Freelander
Jan 28, 2008 02:36 PM
