Technical Service Bulitins
Old Sep 14, 2007 | 04:44 AM
The Grove's Avatar
Default Technical Service Bulitins
Hi Can anyone help me out. I need copied of TSB LA204-008 V2 and LA204-009 V2 concerned with bush settle and air suspension settings on a Discovery 3. I'm having trouble with a warranty claim.
Any help appreciated
Cheers
Old Sep 21, 2007 | 07:16 PM
dirtyduk's Avatar
Default RE: Technical Service Bulitins
Alignment issue ? I'm sure if you have alot of miles and your Good-Year tires are junk You cant get any assistance.
That TSB will only cover vehicles with under 15k miles ,and they pro rate the tires, Rear Tires Only , Inner Wear Only
It was tough to get most approved, and nobody got tires over 20k. I think it only included a small production run too.
The issue here was simply the factory did not align a batch of cars correctly. Also if you get an alignment done, the suspension needs to be locked in alignment mode to even set the alignment correctly. and take my advise and get anything but Good-Year's
Sorry for the reality message . And I dont have a copy of the TSB
Old Oct 12, 2007 | 08:49 PM
dirtyduk's Avatar
(Update ), the factory now covers 100% up to 15k miles and 75% from 15-20k miles,(cost for two rear tires)anything over that needs a dealer rep approval , and pro rating applies. our rep has been declining everyone over 20k any assistance on this issue.but they will correct the alignment after approval, on all vehicles.
jycsalas
May 22, 2015 09:05 AM
rickf325
Oct 20, 2007 06:43 AM
Sparkplugs.com
Dec 1, 2006 03:43 PM
phoenix
Nov 25, 2006 09:22 PM
TrickyS
Nov 20, 2006 10:41 PM
