Thinking of a LR3
Not if you came in on a trail that needs ground clearance. Plus, larger tires and bump stops equals rubbing and no turning. Having had trail failures with mine, it’s always in the back of my mind which ruins the adventurous spirit.
Oh and also just a brake light burning out causes dropping suspension and disabiling off-road modes, transfer case, etc. It’s definitely a love hate relationship!
I've had a couple. First, previous owner replaced rear valve block and swapped lines (not really the vehicle's fault)...but worked perfectly fine until some strong articulation on the trail, system saw the issue, dumped to stops. Second, had a height sensor die, same thing, off road, dropped to stops. Third, thankfully in a parking lot and not on the trail...brake light switch died...back to stops. Fourth, also thankfully not on the trail, compressor internally detonated suddenly.
...please describe.
Sensors don't just die, either. It was likely a calibration issue or torn wires. Anyway...ALL of those issues can be handled easily on the trail. Reboot system, select off-road height, pull F26. Big whoop. No more drama, Mary J!
As for the detonated compressor, I still need to open it up and see. Previous owner just had it put in before I bought it. One day, suddenly, I heard literally a jack hammer under the car. Compressor was shaking itself so hard it was slamming into the frame rail. I can only assume something failed catastrophically inside.
Wow!
First off, you're welcome. I am glad I could help.
Second, that sounds like a one-off situation with the compressor and a scary one. Maybe he went with a cheap product and/or install? Let's rule that one out. My point is that in most cases, and I mean in the high 90% range, on-trail issues that put the EAS at bumpstops can be detected/avoided/fixed and you can get home. I've had a pretty bad one myself, but I got out of it....and in retrospect I should have known my shock was suspect because of the knocking sound that was being made. Nowadays we can jack up the front end pre-trip and make sure there is no interference between the upper control arm and the shock.
The EAS is higher maintenance, but I believe in it. Toyotas are turn-key, I won't argue that...but Rovers are just better.
