Tire and emergency equipment failure question!!!!
Old Sep 15, 2010 | 01:13 PM
tibetrover's Avatar
Default Tire and emergency equipment failure question!!!!
First question...
I have general grabber at2 at 255/55/18 and I have noticed increased amount of wear on both tires on the right side... I'm just wondering what would have caused this, and how should I rotate the tires... Also what tire pressure should I have it set for city roads. I have it set at the standard psi and for some odd reason the tires look under inflated, could it be because it's a a/t tire...??
Second... I was in the process of taking the wheel off so I could take a closer look at the wear on the tires, when the wrench that came in the Landrover emergency kit (u know the things that come with all landrovers to replace a flat tire) BROKE!!!! I was the WTF!? The wrench snapped off where the bolt was supposed to go in!!!
Should I argue with Landrover and some how get a free one... Because I think a wrench is not supposed to break... Espically if it's ment for emergency...
Old Sep 16, 2010 | 07:00 AM
Long Haul's Avatar
#1. I would rotate your tires in an x (left front to right rear an viceversa and right front to left rear an vice versa). If the right side still wears uneven you have a bushing or some thing bad on that side.
#2. I definatly would be going back to LR getting a new wrench but I would be carrying something different like a craftsman breaker bar with the right sized socket. If the LR3 wrenches are anything like the discovery's there junk.
Old Oct 11, 2010 | 01:14 PM
eshew's Avatar
Broke my stock lugnut wrench as well. I think it takes a 22mm socket, went down to my local pawn shop and picked up a craftsman 1/2" socket wrench, correct size socket and a 2" extension for $10. Rock solid now.
Phoenix_522
Jun 9, 2011 09:23 AM
Sultan
Aug 29, 2008 07:13 AM
star_diagnose
Feb 1, 2008 10:56 AM
landlvr
Aug 12, 2007 07:23 PM
