Trailer Hitch
Old Oct 10, 2021 | 11:19 AM
Wrench's Avatar
Default Trailer Hitch
Good Morning!!
I'm towing 2700# (unloaded) camper. It's the 2022 Geo Pro 15TB. ~370# hitch weight.
My 2006 LR3 really doesn't know it's back there. Unless I tell it. The OEM hitch is fine but...
it sits low, to low imo. Requires a 6" riser ball mount to keep the trailer level. The geometry
of the LR hitch and riser is VERY questionable. I want a different hitch...I think Wondered if
some forum members have suggestions. Thanks !!!
Jim
Old Oct 11, 2021 | 02:10 AM
Alex J's Avatar
Wish I had a suggestion but I’m in sort of the same boat. Hopefully I’ll be getting a tent trailer sometime before spring and am looking for a decent hitch besides the factory one. The newest factory hitch doesn’t hang that low but the cost of them is too high for me.
Old Oct 11, 2021 | 11:09 AM
douglastic's Avatar
I have the 3rd Gen LR040248 which is a MUCH better/compact design
With just a 2.75" riser, I can reach ~21.5" hitch height
Used ones come up often enough, just be patient and/or post a WTB
Old Oct 11, 2021 | 01:40 PM
Wrench's Avatar
Default Looks like this will work....
OEM hitch with a 4" riser....
Pretty stinkin' level
Old Oct 11, 2021 | 02:39 PM
douglastic's Avatar
Note: The manual says "maximum recommended drawbar rise is 2.75in."
Do with that info what you like - I wanted to make sure I was within spec, for insurance purposes.
Old Oct 11, 2021 | 05:11 PM
Wrench's Avatar
Totally get it. I am waiting for this part to get back in stock (wish me luck) Definitely sits higher than the old one in my photo. https://www.roverparts.com/exterior-...s/LR019990ABP/
That and a 2" riser has to be close....
Old Oct 11, 2021 | 05:13 PM
DakotaTravler's Avatar
Just adding that folks need to keep an eye on the early OEM hitches, they tend to crack and can fail.
Old Oct 11, 2021 | 05:35 PM
Wrench's Avatar
I can imagine. They look almost like a casting.
Old Oct 13, 2021 | 12:02 AM
5280LR3's Avatar
That's quite a statement... what data do you have to back it up? I've seen dozens of these inserts and have never seen a failed one...
Old Oct 13, 2021 | 12:15 AM
loanrangie's Avatar
Although the English hitches are a bit different (they don't use a 2" reciever) they fail a lot hence why most that tow regularly fit an aftermarket towbar system.
I have a Mitch hitch which is an Australian made high rise hitch that uses 50mm tongues that doesn't affect ground clearance and better suits my off road camper trailer.
