Transfer Case ECU ??
Old Sep 18, 2020 | 03:05 PM
soarvet's Avatar
Default Transfer Case ECU ??
I need to replace my TCCM. Does it have to be the same part number or can you use a different part number. They all look the same. Mine is a NNW502932. I see 7H42-7H417-AC, NNW505090, etc.. Want to make sure I look for the right one.
Also, I know if I purchase a brand new one it has to be programmed. Is that something you can do with the GAP tool? I think I read a used one you can just swap them out, but is there any update you have to do to it so it works?
Old Sep 25, 2020 | 09:26 PM
soarvet's Avatar
Well I ordered the same model/part number from my original one, got a replacement off ebay for $120. Came in today. Swapped it out and everything is now working. I had special programs off and unavailable, transmission fault. The terrain management **** would not light up and transfer case would not go into low. Also had no sport mode. Talked to the guys at GAP, they advised if I was buying a brand new TCCM that I would need to flash the ecu to sync it up with my vehicle. If I bought a used one I may or may not need to flash the ecu depending on the software version.
Everything is working right now, but I’m gonna shoot my ecu info over to GAP and see what they recommend. They also said I’d need to do a calibration with either, all easily done with the IIDTool.
Old Sep 25, 2020 | 11:00 PM
DakotaTravler's Avatar
Good info! Thanks for the update!
Old Sep 26, 2020 | 05:15 PM
soarvet's Avatar
Thx, figured I’d update my post. A lot of people don’t update their posts after they find a fix. It’s irritating to search for an issue only to find nobody posted a solution to their fix. This forum has been a great help to me since 2007 when I bought my first LR. Just trying to do my part.
Old Sep 28, 2020 | 10:16 AM
soarvet's Avatar
Update: Sent an email to GAP this morning, they replied within a few minutes.
"If it works, leave it alone even if it came from another car. You have to calibrate it thought, Menu--Calibration-TCCM, proceed with both items. It may require more than one iteration."
Just went and ran through both items in the menu, calibration and sensor something. A bunch of clicking from the transfer case motor and moving the selector to hi and to low and all is well. Gotta tell you, GAP Diagnostics staff are great.
Old Sep 28, 2020 | 03:13 PM
AtlantaViking's Avatar
Thanks for the info! I couldn't tell though - was the TCCM that you bought new or a used one? Really curious because I picked a new one up a while back when my was acting flaky but it turned out to be oxidation in the connector but I wouldn't mine replacing it.
Old Sep 28, 2020 | 06:52 PM
soarvet's Avatar
I ordered a used one off eBay. Figured $120 was better than $300. I pulled my original out and it didn’t have any corrosion, pins looked good, so I don’t know what happened to it, but it was bad. Drives like new now.
Duke Duvenstedt
Engine Swaps
Jul 21, 2020 09:03 AM
mattrickman
Nov 16, 2011 04:38 PM
wilson96rr
Jan 4, 2009 04:15 PM
BeanBean
Oct 12, 2008 02:32 AM
alex of minnesota
Dec 13, 2006 08:41 PM
