Transmission “fixed” but now I’ve lost sport and manual mode
Old Nov 19, 2019 | 04:41 PM
03evan's Avatar
Did you remove the plug before you tried to push the sleeve in further? I’m pretty sure that the latch on the mechatronic itself will prevent the sleeve from moving any further once it’s latched.
Old Nov 19, 2019 | 04:52 PM
gervin23's Avatar
I didn't mess with the sleeve after the first install, just the plug and the tightener.
Old Nov 19, 2019 | 05:00 PM
03evan's Avatar
Does your sport mode work at all?
Old Nov 19, 2019 | 06:14 PM
Blackngold77's Avatar
Thinking in the sense of dot every "i"...you follow the fill procedure correctly? Could be low on fluid if not
Old Nov 19, 2019 | 06:36 PM
gervin23's Avatar
Sport mode works as does downshift (-). Only thing not working is upshift (+) in manual mode.
I'm pretty sure I did everything right. One thing I didn't do was apply gasket sealer like the AB video suggests and now I have a small leak in the back of the pan.
Old Nov 19, 2019 | 06:56 PM
LR Techniker's Avatar
Originally Posted by 03evan
I’m not 100% sure what you’re asking.
Initial post said that you replaced the solenoids. In order to replace them, you have to remove the black plastic frame that plugs into the solenoids. That black plastic frame is the Transmission Control Module (TCM). On the side of the TCM is a position switch (tan or brown) and engages the manual valve and moves in conjunction with the shift cable.
When putting the TCM back on, did you properly align the sensor with the shift valve?
Old Nov 19, 2019 | 07:29 PM
03evan's Avatar
ah. Yes. That was triple checked before I put everything back together!
Old Nov 19, 2019 | 07:31 PM
03evan's Avatar
My issue appears to be electrical. My vehicle isn’t even recognizing that I’m in M/S mode. The shifter illuminates m/s, but the TCM live data states that the vehicle is in drive and specifically states that m/s is not selected.
Old Nov 19, 2019 | 08:41 PM
5280LR3's Avatar
I believe this is what Techniker was referring to. That is why I asked if the PRN message was displaying correctly in the message window. If this isn't installed correctly, I found that message for the gear indicator was off to what the actual shifter position was. Don't ask how I found this out... BTW, I did not attempt to drive it or move the shifter to the command mode so I don't know how this may/may not affect your situation.
Old Nov 19, 2019 | 08:53 PM
03evan's Avatar
Yeah... I made that mistake on my 06 RR. Both the dash, center console, and my scan tool read the proper gear until I shift to m/s. Then everything pretends like I didn’t do anything except the m/s lights.
