Transmission fluid flush/change
Old Jun 20, 2013 | 06:10 PM
er1c's Avatar
comleader, yeah I had to jack up the engine and unbolt part of the exhaust.
That's another reason why I did the steel pan conversion. With the steel pan, you don't have to raise the engine. Plus, like I said above, you can buy a new tranny filter without having to buy a whole new pan.
If you're interested, I can get you a list of the part numbers plus give you the contact info of the company I sourced the parts from. Let me know.
Old Jun 21, 2013 | 07:47 AM
comleader's Avatar
Thanks. I would really appreciate that.
Old Jun 21, 2013 | 08:59 AM
thorgal's Avatar
BG transsmision flush works well, but it needs 16 quarts of fluid , not 10 ,like double flush. This is due to the fact, that BG machine requires 16 q to start and work properly.
Old Jun 21, 2013 | 01:58 PM
er1c's Avatar
comleader,
For the steel pan conversion, the part numbers are as followed:
Steel pan: 1068-203-042 ($117.81)
Bolts (21 of them): 0736-010-347 ($2.45 * 21 = $51.45)
Replaceable Filter: 0501-213-359 ($47.36)
Gasket: 1068-303-017 ($22.82)
I ordered them from "Eriksson Industries" erikssonindustries.com. They're located in Connecticut and I recommend them.
It took about 5 weeks to special order the parts from Germany until they arrived at my house. My receipt came out to a total of $250.50.
Old Jun 28, 2013 | 04:20 PM
rewillia's Avatar
Took mine (05 LR3 HSE) to my local Indy (independent shop) and they changed filter, flushed trans and refilled with new complete fluid fill for about $280 and that was using a Land Rover OEM trans filter with gaskets, replacement o-rings including the filler tube o-rings.
Old Jun 28, 2013 | 07:46 PM
Mack73's Avatar
I'm going to guess they didn't actually "flush" the fluid. This sounds like they drained, swapped the gasket and filled. The problem is 50% of the oil is still in the torque converter. Doing a proper flush would eat up most of the 280 in the oil alone.
One method I've heard is a "double flush". Drain then refill. Drive it to mix the oil. Then drain and refill again. Yes there will be some old oil left (max 25%) but you've replaced at least 75% of the oil.
Old Oct 20, 2017 | 12:32 PM
discoverybrazil's Avatar
I did changed my trans oil on my lr3 2006 with 130000km by flushing 10 liters and is fast and great!!
Old Nov 27, 2024 | 04:31 PM
irontmp's Avatar
Banned
If you're interested car zinity, I can get you a list of the part numbers plus give you the contact info of the company I sourced the parts from. Let me know.
I was at the dealer and they are saying when MM says change trand fluid, they remove all the fluid via a machine and replace it with new repalcing almost 110%. I was under the impression using a machine on the trans is no good what gives ? Anyone dealt with this situation ?
Old Nov 27, 2024 | 04:48 PM
Default Flushing 10l motul mult atf
i done on my car put around 10L motul mukt atf + 2 lubegard by flushing 7 years ago then. My car is great! Ill make it again shortly
Old Nov 28, 2024 | 12:06 PM
DakotaTravler's Avatar
I think the issue with using a machine is the filter is not replaced. But really the filters last a wicked long time and its not like engine oil that can get contaminated. I would have no issue using a machine with the only caveat being that I would want the filter changed at no more than 200,000 miles. I think that is plenty for any modern trans filter.
