Transmission Oil and Filter Change
Old Apr 4, 2016 | 10:38 PM
Paul Flannigan's Avatar
Default Transmission Oil and Filter Change
I'm studying up on how to change my 06 LR3 SE's transmission pan/filter and oil. Found this
and thought it was pretty cool.
I'm using this non-OEM
ATP B-409 ATP B-409
pan and http://www.roverparts.com/Parts/LRN13754ZF.
Old Apr 5, 2016 | 06:47 AM
cmb6s's Avatar
Here's the post that I did previously on changing my tranny fluid. Note that I did not change my pan/filter because it had been done previously and I don't think there is any reason to do that before 150,000 miles. However, it gives the steps for refilling the fluid somewhere down the page. Hope it helps a little.
https://landroverforums.com/forum/lr...uestion-72231/
Old Apr 5, 2016 | 07:52 AM
cmb6s, very interesting process, thank you! Can't wait to deal with the fill plug next to the glowing exhaust, while on jack stands. Fun times.
Old Apr 7, 2016 | 11:04 AM
DavC's Avatar
FWIW this was one of the things, like my very rusty control arms, where I just had the dealer do. Excellent write-up by cmb6s previously. For you bean-counters out there I think I paid $1400 for this service (pan, bolts, fluid, sleeve, and several hours of labor). I work way longer hours now and couldn't spare the time to muddle through myself . That said I trust my dealer here to just get it done right.
the 12 month warranty on the parts/labor I do appreciate though. Re: the interval for changing pan/filter/fluid I have heard anecdotally but never "officially" confirmed with ZF that 75k is a good time to do it. LR dealers don't want to touch it before 150k, say it is lifetime-rated (ZF brochure says the same).
Old Apr 12, 2016 | 02:21 PM
Turns out the ATP-B-409 pan has the dang OEM tube that requires lifting the engine to install. I'll have to try and return this and look into the metal pan or a flush.
Or just screw it and see how long these sealed transmissions really last.
ATP B-409 ATP B-409
pan and http://www.roverparts.com/Parts/LRN13754ZF.[/QUOTE]
Old Apr 12, 2016 | 04:04 PM
BritishautoworksSD's Avatar
$1400... yikes! We get this done on Range Rover Sports and LR3s for about $800. We also replace the transmission connector sleeve at the same time.
ZF does state 80,000 km/8 years for fluid changes.
List of lubricants - ZF Friedrichshafen AG
Click on TE-ML 11
Old Apr 12, 2016 | 04:34 PM
DavC's Avatar
Pete,
I'll tell you what. Next time I need this done at 180k I'll book a hotel and call it a beach weekend down at your shop . That extra $600 is a lot of pina coladas to work with....
Old Apr 12, 2016 | 04:39 PM
Now your talking! Or a craft beer tour! I'm 3 miles south of the 78 which is also called "Hop Highway" About 15 craft breweries in a 5 mile radius.
Old Apr 12, 2016 | 04:44 PM
houm_wa's Avatar
Mmmmmm.....Green Flash.
luckyd77
Jul 2, 2017 09:06 PM
revel8or
Jan 23, 2014 05:55 PM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
