Transmission Shifting Problem
Old Feb 25, 2014 | 11:54 AM
tbendekovits's Avatar
Default Transmission Shifting Problem
This issue is a little perplexing to me. On various days, my LR3 is having some shifting problems. On occasions, typically first thing in the AM, after my first stop at a red light, the truck will start out in third gear. Once I get up to speed, it will shift into fourth as required. After I stop again, the truck goes back to first gear and is fine for the rest of the trip. Any idea on what this may be? I let the truck warm up for about 5-10 minutes in 30 degree weather.
Old Feb 26, 2014 | 10:17 AM
Zach.K's Avatar
Only thing I can tell you is you need to stop letting the truck sit there warming up. It benefits nothing and is worse on the engine to idle cold under no load.
How many miles and when was last transmission service?
Old Feb 26, 2014 | 10:19 AM
unseenone's Avatar
Another possibility.
Are you in a rust belt? The shift lever / assembly is a known issue due to corrosion.
Old Feb 26, 2014 | 10:35 AM
houm_wa's Avatar
My question: How do you know precisely which gear the vehicle is starting out at after the stop?
Old Feb 26, 2014 | 12:15 PM
Not sure when granny was serviced last. Waiting on the private mechanic to get back from"vacation". I live on the East Coast about 2 hours from the ocean so rust. Possibly. On occasions, I have to push the gear shift back to get into gear. As for knowing what gear. I do t actually know. I assumed because of how bad it lags trying to get up to speed. Around 30-40 is when it feels normal
Old Feb 26, 2014 | 01:25 PM
Zach.K's Avatar
Have you tried it in gear select mode? Force start from 1st gear to see if the lag exists there? If still there I'd say its high time for a service.
Old Feb 26, 2014 | 03:12 PM
houm_wa's Avatar
Good point. If it's a "lag" then there is a DIY "tune" you can do by putting the ignition in position II and holding the throttle to the floor for 5 or 10 seconds (I don't remember which) and then removing your key and letting the LR3 go to "sleep."
...don't ask me why this works; it just does!
Old Feb 26, 2014 | 10:00 PM
Zach.K's Avatar
Good chance it's an alignment or relearn command. Find more if you can because mine can use this.
Old Feb 27, 2014 | 04:00 PM
houm_wa's Avatar
There's not much more to find...that's how you do it.
Old Feb 27, 2014 | 07:27 PM
Zach.K's Avatar
Well when you say you don't remember which, it makes me think your not sure.
