Transmission Whining
So I picked up a new to me 08 LR3 with 120K on the clock. The P/O Bought it certified and had a huge folder of service records and receipts. One of which was a Transmission flush done around 80-90k (I will have to verify).
I have noticed a whine that seems to becoming from the transmission. It is RPM dependent, whines while stopped and driving, and sounds just like the classic dodge tranny whine. The transmission seems to shift fine other than it likes to hold first gear when it is cold. Anyone had this issue? I was thinking about checking fluid level, but need to do some research since it seems to be a process on these trannies. Any thoughts would be great.
Changing/flushing the fluid on the V8 is dead easy - using the line to the cooler. You can get about 5L out and in doing that. Then drive for a bit and do it again. You'll replace the whole volume after two cycles. It makes a considerable difference. Basically you're taking the feed from the transmission to the cooler and draining it - takes about 20 secs - then refilling via the same route (you can refill using gravity or using a pressure sprayer set up). I'd start here: https://www.disco3.co.uk/forum/filos...2Btransmission
Try this and see if it makes a difference. Personal preference but I would only use Lifeguard ZF6. It's perhaps more costly than alternatives but it's the spec fluid and if you plan on keeping the vehicle is a good way to go.
100% certain its mechanical and not coming through the audio system? I am guessing not, but want to be sure since the audio system on this truck can pick up trans whine, especially in aux mode.
I would also look at the diff, transfer case fluids. Any of those can cause noise too. I just helped repair an LR3 that had a horrific noise when driving, convinced it was the front diff. Just a wheel bearing, it was amazing how much the sound traveled around the drivetrain.
If you need trans fluid, you can use Motorcraft XT6QSP, its identical spec to the overpriced Lifeguard 6 and many LR3 owners use it without issue.
Sounds about right - Check the pan. If it's metal it was definitely changed.
Do you mean the transmission fluid was changed at 111K? If so, and you have absolute faith it was done then it's only done 9K on the new fluid so I wouldn't normally bother. However, it's a cheap and very easy thing to tick off your list when fault finding. First, and to DTs point above, I would suggest first sticking the thing on a pillar lift and ruling out the hubs. If the hubs haven't been changed they'll probably be on their last legs at 120K if not completely shot. From experience the best way to figure it out would be to run it with all the wheels off the ground and pinpoint the noise that way. You could also then play hunt the whine since you could listen to the transmission at the same time.
peter r
12-30-2022 08:08 AM
Snafu / Disco Fries
12-07-2011 10:18 PM
