Trouble with LR3SE 2006 today..
Old Apr 28, 2018 | 12:52 PM
Athana's Avatar
Hi does not look wet or Corroded. : (
But put battery back in..fiddled with brake light switch and now we have another fault code (Parking Brake and abs indicator) on top of first faults and now will not respond to lift to driving height and terain settings so now can not drive to dealer on Thursday.
Took to repair shop for throttle body cleaning and change a brake light and they made a mess of it.
Lost two days of work and the day of the job.
Not to mention my neighbor took Trottle body off and the side attached to intake was not cleaned.
A nightmare and to have to go to dealer where they charge near 3 times a regular shoppe.
Old Apr 28, 2018 | 02:01 PM
You pulled the connection loose to verify correct?
Old Apr 28, 2018 | 06:22 PM
Athana's Avatar
Took battery out again ..front connections of Module were good but reaching into back pulled those terminals and ..yes connection corroded.
Just got some terminal cleaner.
What do you think?
Old Apr 28, 2018 | 06:23 PM
Athana's Avatar
Just relooked did it and described above by mistake..
and now it's raining again.It has been raining almost every day.
Old Apr 28, 2018 | 06:47 PM
Electrical cleaner of your choice soft bristle tooth brush and dielectric grease should be good to go
Old Apr 28, 2018 | 07:54 PM
Athana's Avatar
Hi..I bought
Lynx Battery Terminal Protection kit..I think I may have got the wrong thing?
I' have regular electrical contact cleaner ..and toothbrush..but now I need dielectric grease from autozone.
Old Apr 28, 2018 | 08:01 PM
This stuff
https://www.zoro.com/crc-electronic-...BoC7bsQAvD_BwE
Old Apr 28, 2018 | 08:25 PM
Athana's Avatar
Ive got: CRC QD Electronic Cleaner.
Will that be ok if I don't find the pictured one by CNC at AutoZone? thanks
Old Apr 28, 2018 | 08:26 PM
that will work
Old Apr 29, 2018 | 09:46 AM
Athana's Avatar
that will work
Hi..plugged in but same warnings appear.. connection good.
The source begins at Trottle body cleaning and wrong brake light bulb..
​​​​​​Am using Sylvania 7528 bulbs now.
