using the axillary outlet
Old Sep 18, 2008 | 02:39 PM
GoofyMD's Avatar
4th Gear
Default using the axillary outlet
this may be a stupid question, But I am going to be tailgating this weekend and thought I'd plug something in to the axillary outlet in the back. I was concerned about how long I could run a radio or Tv so I looked at the owners manual, which said not to use unless the engine was on. I don't want to drain the battery and not be able to start the car, but what's the point of an outlet for camping if you can only use it while the car is running.
have you use it with the ignition off? if so for how long?
thanks
Old Sep 18, 2008 | 06:43 PM
offroadlr3's Avatar
Default RE: using the axillary outlet
It shouldnt be a problem... I have used to radio for half an hour or more... then ill just turn on the car for like 5 minutes and back to using radio....
Old Sep 25, 2008 | 02:23 PM
LR3Crwlr's Avatar
i have also noticed my radio says "low power mode" after listening with the vehicle off for extended periods of time. I am assuming this means that the amps are shutting down? I also assume that the battery should kill everything if it starts to get low? My silverado will kill everything to make sure you have enough juice to crank the truck if you leave the radio on too long.
Old Sep 25, 2008 | 08:20 PM
drzjoint's Avatar
just pack some jumper cables or batt. booster and have a good time
928paul
Dec 12, 2011 07:26 PM
newBrover
Jul 25, 2010 04:57 PM
Phototone
Apr 16, 2008 01:14 AM
Phototone
Audio/Visual Electronics
Apr 16, 2008 01:11 AM
BuffaloRider
Nov 9, 2006 10:11 PM
