Valve block connector help.
Hi.
Lesson #1 for me today meant, that I should never replace something that it is not entirely out of order, a day before long trip. I changed oil , topped off front diff, check under for leaks and such and also decided to replace a front air suspension block valve. Simple task turned out to be a disaster as the usual suspect, plug on the car harness side has a broken orange rubber gasket inside the connector. Therefore I could not press a nw valve block female connector into it as the broker gasket would not allow me to fully seat the male part. Out of frustration I removed the rubber and both connectors finally clicked. It is not weatherproof for sure but I used a rubber glove and some electrical tape to waterproof it. My question i, do anybody knows where I can purchase this plug separately for a future replacement? When I called a local dealer, they aid that serviceable part on LR end seas not exist. What are my choices here ?
I had the SAME problem! In fact, its in a thread some place or a comment about how I serviced mine and it held for a long time until I did some touch trails, it started to break connection ever so slightly. Caused all sorts of confusion for me. So when I figured it out, I did the same. Took the orange seal out. I have been doing stupid stuff for some time and its not been an issue like that, but I did get a new connector from Atlantic British. It was not much, like $11 shipped. I just have to install it when I have time. Search their site for part: YPC800230G
Thanks Dakota Travler.
I apologize for not responding earlier as we were on camping vacation in place where was no service to respond whatsoever and that is how we like it ! J/ust came back last night. Now, In regards for a serviceable connector, were you able to de pin those six wires or just cut, strip and insert?
