Valve blocks
It's odd when looking OEM - they interchange the part numbers RVH000055/RVH000095 as compatible. Talk about confusing.
55 is rear 95 is front.
"The front and rear axle valve blocks are similar in their design and construction and control the air supply and distribution to the front or rear pairs of air spring damper modules respectively. The difference between the two valves is the connections from the valve block to the left and right hand air spring damper modules and the valve size. It is important that the correct valve block is fitted to the correct axle. Fitting the incorrect valve block will not stop the air suspension system from functioning but will result in slow raise and lower times and uneven raising and lowering between the front and rear axles."
Not mentioned, but to add to above. The issue is if the raise or lower time is off enough the computer faults because it feels something is not right. Thats generally when people learn they are not interchangeable.
Also buy genuine or rebuild an old one, the knockoffs don’t have functional cross linking and the valves seize quickly because the internals are made of cheap zinc plated steel or maybe aluminum.
There is a third valve block mounted on the frame just ahead of the compressor. This controls flow into and out of the reservoir tank.
Hi so this middle valve block does not come as part of a new Compressor right ? Thanks.
