Water in Passenger Front Footwell
Hello, I’ve looked into regular culprits for this problem but I’m looking for further advice. I have replaced the front cowl and sealed sunroof (it’s no longer operational) so I’m not sure what my next steps should be. My mechanic says I need to replace the sunroof itself but that will cost me about $2k which is a frightening amount.
Thanks in advance
Thanks in advance
Thank you for your response. How would I shield the pollen filter box? I have not done anything there. I also haven't checked if it's wet when the footwell is. Is that likely?
How would I check the a-pillar? My understanding is the drainage hose from the sunroof is much more complicated to access (and beyond my capabilities) compared to the drivers side drainage hose.
hazletbassist89
12-15-2008 02:17 PM
