Water in Passenger Front Footwell
Old May 3, 2022 | 06:11 PM
thaBink's Avatar
3rd Gear
Default Water in Passenger Front Footwell
Hello, I’ve looked into regular culprits for this problem but I’m looking for further advice. I have replaced the front cowl and sealed sunroof (it’s no longer operational) so I’m not sure what my next steps should be. My mechanic says I need to replace the sunroof itself but that will cost me about $2k which is a frightening amount.
Thanks in advance
Old May 3, 2022 | 09:06 PM
houm_wa's Avatar
Did you shield the pollen filter box? Have you checked the A-Pillar?
Old May 3, 2022 | 10:00 PM
thaBink's Avatar
3rd Gear
Thank you for your response. How would I shield the pollen filter box? I have not done anything there. I also haven't checked if it's wet when the footwell is. Is that likely?
How would I check the a-pillar? My understanding is the drainage hose from the sunroof is much more complicated to access (and beyond my capabilities) compared to the drivers side drainage hose.
Old May 3, 2022 | 11:05 PM
houm_wa's Avatar
Shield it by attaching a piece of thing metal or plastic or even laminated paper. Then for the A-Pillar there are holes you can just duct tape over.
kmelesky2
Feb 27, 2017 05:33 PM
CATTIVA73
May 23, 2016 06:19 PM
LRgirlfromMS
Mar 6, 2013 03:51 PM
Bad News
Aug 27, 2010 06:05 AM
hazletbassist89
Dec 15, 2008 02:17 PM
