Well I just dropped $434 at the LR dealer and got no where!!
Old Jun 7, 2015 | 07:36 AM
  #21
threalassmikeg's Avatar
PM me your phone#
  #22
Disco3JR's Avatar
Originally Posted by threalassmikeg
Can you bring the vehicle back?
C1168/1 (pin1) is the lin bus communication line from the front to the rear climate control modules,
a logical place to start given the lin bus fault supplied by the dealer tech, and its location in the vehicle.
The front distribution, and blend, and recirculation motors are hard wired to the front climate control module.
they use a lin, or k bus for comms. faults with the servos typically flag for the respective servos, not lin.
it would be nice to see all the stored codes. I would suspect you have more than one issue with this vehicle.
What does not function with the rear climate control? Just the blower Motor?
I picked up a scanner last week I'll post the codes shortly..
Thank you again for all the help I am starting to feel better about this mess!!
Old Jun 7, 2015 | 08:52 AM
  #23
you can call me, just pm me your #
Old Jun 7, 2015 | 10:29 AM
  #24
Disco3JR's Avatar
Ok.. Here are the codes..1-9 total
B1A98 Lin bus circuit 1
B1b70 Lin bus circuit 2 x'2
B1b74 Front foot defrost mode stepper actuator.
B1b75 Front foot – face mode stepper actuator
B1b76 Front left Air blend stepper actuator
B1b77 Front right air blend stepper actuator
B1B82 rear air distribution stepper actuator
B1b83 rear air blend stepper actuator
Thanks for everyone's help!!
Old Jun 11, 2015 | 04:30 PM
  #25
TOM R's Avatar
first on the sunroof, open it and go to the 2 front corners you will see the drain holes, blow compressed air in there to clear them then dump water in them and it should run out the bottom of the a pillars, look in tech section for pics and how to, if these are clogged which is common, when it rains enough the water puddles in the headliner and will run onto the center console shifter area radio and nav., happened to my wife
invest in a good solder irin and solder, flux shrink tube and wire, that blue tape in your pics are splices, tug on em they will probly come apart and need to be stripped back and resolder
buy a good size tube dielectric grease, any connectors you can get to clean with electronics spray cleaner then slather with that dielecetric grease and plug back together this also goes for under the car and under the hood,
esp the trans ecm behind the batterywater runs into that connector and by by trans
this is all very overwhelming and frustrating so if you are not up to all this and the electrical gremlins continue i suggest trading it in
unfortunatly perfect example why we recommend the rover dealer inspect the car before you buy it
good news is once this is all straight the car is awsome to drive
Old Jun 11, 2015 | 09:02 PM
  #26
Disco3JR's Avatar
Thank you for the tips, I'm going to get this truck figured out if it's the last thing that I do! Ill work on cleaning and greasing all connectors that I can reach good tip on the one behind the battery I'll get to it as well. Also thanks for the tip on the blue taped wire soldered joints, I pulled one apart and it looked ok but I'll examine closer.. I discarded 3 of the connectors and hard wired them together minus the connectors because they were directly under the drivers side sunroof drain tube getting regular watering with each rain storm. (Looks like months perhaps) they were very corroded and kind of greenish blue in color on the metal pins or the female metal plugs as well... When I reconnected the battery I have noticed that the vents are now blowing luke warm air and "only" Luke warm air.. Not hot like it used to be and not cold...?.. The program light on the temp control module will now flash when I turn the truck on for 10-15 secs or so which I've heard signals that there's a problem with one or all of the stepper motors/actuators?. I've been drying the underside of the carpet/pad out as best as I can but that stuff was soaked as if I dumped a bucket of water on it!.. I'll dig into the truck more this weekend and report my findings..
Old Jun 12, 2015 | 07:26 AM
  #27
TOM R's Avatar
Getting that carpet dry and stopping water ingress is first step
Blow out the sunroof drains, make sure they are draining outside, pull the black a pillar covers outside Rtv glue around all holes for the clips , pull Beth sides of front carpet up best you can and wring out the water then sop it up, it takes forever to dry, leave sills off and no floor mats, windows cracked on nice warm day when no rain
Look in lr3 tech section
Old Jun 12, 2015 | 11:41 AM
  #28
Disco3JR's Avatar
I just looked through the lr3 tech section great stuff in there!!
I'm working on drying out the carpet like you suggested it's already a lot better than it was last weekend.!
Thanks !!
Old Jun 12, 2015 | 06:46 PM
  #29
TOM R's Avatar
Click in my 05 lr3 link below water ingress ruins these vehicles
Old Jun 12, 2015 | 06:55 PM
  #30
hell pie's Avatar
Water can also enter through your cabin air intake. Check your cabin air filter. It is probably wet. I think it is accessed from the glove box.
