What is this?
The pigtail for them is very short. They are quite annoying to disconnect the first time. Along the fender liner there should be two screws inside a three-pronged plastic rivet. Withdraw the screw, collapse the prongs, and insert the prongs in the fastening holes on the antenna. Drive the screws into the rivets and that will hold the antenna in place.
OR..... if you have long enough arms, just reach up under the front portion of the liner and disconnect them.
Jeff
