what is this????
Old Jul 29, 2016 | 10:36 AM
Roverrrgirl's Avatar
Default what is this????
Hallo..anybody know what this gray plug is and if its supposed to be connected to something??? its located under the steering wheel column, I noticed it when I replaced the brake light switch and removed the plastic panels
Also when I read the fault codes with my i930 scan tool this one keeps coming back: "Lost communication with ECU"..check connection..:
is this plug related to the faulty code at all? if not what exactly do I need to check to fix this fault ??
Thanks
Old Jul 29, 2016 | 07:34 PM
roverguy7's Avatar
It should not be connected to anything, it is the factory wiring harness to add a trailer brake controller.
As to the fault, it all depends on what ECU cannot communicate with which other ECU. These faults aren't that uncommon to have, so as long as everything is functioning correctly, don't worry about it too much.
Old Jul 30, 2016 | 07:06 AM
Thank you
Old Aug 1, 2016 | 01:10 PM
bbyer's Avatar
Default Would you believe a Ford plug?
For what it is worth, an adapter part number is Tekonsha 3035-P from the "Ford" plug to a Tekonsha brake controller.
DISCO3.CO.UK Photo Gallery - NAS Trailer Socket Pin ID and Wire Colours
DISCO3.CO.UK Photo Gallery - NAS Trailer Socket Pin ID and Wire Colours/Tekonsha Ford Brake Controller Adapter part number 3035-P
