What can cause Transmission Fluid leak?
Old Sep 11, 2022 | 12:29 PM
  #31
DakotaTravler's Avatar
You should be collecting that fluid in something clean to determine if it looks dark or not. Dark fluid would be a bad sign of course.
Old Sep 11, 2022 | 07:13 PM
  #32
martymart's Avatar
This
This is how much has connected in 3 hours! Almost two inches in a 4” drain cap. when compared to fresh here it looks a little dark, but it does have almost 170k miles….
Old Sep 11, 2022 | 07:16 PM
  #33
170k miles? Yeah... its not so bad really but it would be hard to tell with those miles especially since the trans fluid is gold to begin with, not red. And that valvoline crap is not the right fluids for the trans by a long shot.
Old Sep 11, 2022 | 07:25 PM
  #34
martymart's Avatar
I know it’s not the right fluid. The shop put the right landrover trans fluid in, but this was the closest I could get when in a pinch.
​​​​​​​left is old. Right is new.
Old Sep 11, 2022 | 07:27 PM
  #35
Like I said, hard to compare side new is not gold its red. I know you added some. But the original is light gold and with 170k... How does it smell, does it smell burnt?
Old Sep 14, 2022 | 05:55 PM
  #36
martymart's Avatar
No, doesn’t smell burnt. I’m getting prepped to pull it. No matter what, some seal is leaking, and I can’t really hurt it worse than it is (famous last words) so I’m going to pull it and take it apart. There’s some great rebuild videos out there. this time I will make a transfer box removal video too.
Old Sep 16, 2022 | 08:11 AM
  #37
P-Bod's Avatar
I get it!
I tell myself, I’m either gonna break it all the way, or fix it.
Old Sep 20, 2022 | 01:24 PM
  #38
martymart's Avatar
alright... i've got an update. The transfercase, is fine, the front driveshaft has broken at the flange to the transfercase. I think i damaged it during the first xfer case swap.
I've got everything prepped and ready to pull the transmission out and find out what's going on to cause the leak. I'm a little nervous reading about potential issues with the torque converter, but tomorrow i plan to bust out the pry bars, slide this tranny out and and see what's going on.
Old Sep 22, 2022 | 11:15 AM
  #39
martymart's Avatar
got the transmission off and started the rebuild... it was really stubborn to get off.
here's inside the bell, very very dirty in there, as well as throughout the valve body and clutch packs
Old Sep 22, 2022 | 04:24 PM
  #40
P-Bod's Avatar
I hope I don't need to do this any time soon, but THANK YOU for documenting your progress for the rest of us. Transmission fluid is a good solvent, and you can clearly see it's trail!
