What could the problem be?
Old Nov 4, 2013 | 10:21 AM
jnew222's Avatar
6th Gear
Default What could the problem be?
Ive been having suspension problems lately and im not sure what the cause could be. I get the suspension fault "normal height only" on the dash and the vehicle wont raise and is pretty much on the stops in the morning. There was a blown fuse and although replacing it fixes the problem temporarily it only last for about 4 or 5 days before i get the fault again and the process repeats itself. Any ideas?
Old Nov 4, 2013 | 10:24 AM
coors's Avatar
Will the fuse blow following replacement?
Old Nov 4, 2013 | 11:34 AM
jnew222's Avatar
6th Gear
Yep. I just put a new fuse in about a week ago and now im going to have to go get another.
Old Nov 4, 2013 | 05:25 PM
willrok13's Avatar
First things first, are here any codes tripped?
Old Nov 10, 2013 | 01:40 PM
L.R. HoustonTech's Avatar
3rd Gear
Most likely if you pull codes there will be a code c1a24-60 for suspension compressor fault. Although the compressors fail all the time a leaking air spring can cause premature failure due to keeping up with the leak. There is a new compressor kit with relay that you can install and AMK compressor which requires some modification to hose, new relay and a reflash of the ride level module.
Old Nov 11, 2013 | 06:27 PM
roverguy7's Avatar
What fuse is blowing?
Yikes!
Apr 9, 2014 09:33 AM
unstable
Sep 12, 2009 09:33 AM
underpsi
Apr 30, 2008 09:59 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
