Wheel bore out info
Old Sep 14, 2017 | 09:39 PM
stevemaxfield's Avatar
4th Gear
Default Wheel bore out info
Wanting to fit some 18 inch Hurricanes to my 07 V8 LR3 and could do with supplying my metal shop with info on how much the hubs need to be bored out.
Do any members have experience of having this done?
Many thx
Old Sep 14, 2017 | 09:45 PM
IIRC the center bore needs to go from 70.1 mm to 72.6 mm
No idea on getting it done.
Also be sure to look at the strength of those rims. The LR3 weighs in at 1300 lbs more
Old Sep 14, 2017 | 11:47 PM
4th Gear
I've also heard I can fit spacers rather than bore out the wheel centres
Old Sep 15, 2017 | 07:54 AM
I'm sure you can. Not sure I would. Why not find a set of 18" LR3 wheels
Old Sep 15, 2017 | 11:30 AM
4th Gear
This is probably the best solution but there arn't too many 2nd hand options here in Vancouver and I really like the look of the Hurricanes 🤔
Old Sep 15, 2017 | 01:07 PM
Fair enough check ebay for spacers
Old Sep 16, 2017 | 12:32 PM
DavC's Avatar
I agree. I see zero utility in modifying to something non-standard.
Old Sep 18, 2017 | 01:00 PM
houm_wa's Avatar
Especially if you only want 31.5" tires...you can do that stock. Or at min with an IIDTool, which you should have anyway.
Fast951
Aug 3, 2016 08:29 AM
Charlie_V
Aug 27, 2015 04:43 PM
HammerFit
Oct 9, 2014 10:26 AM
honda50r
Jul 22, 2011 08:11 AM
audiS4S6
Apr 20, 2010 08:35 PM
