Wipers blades don't go down all the way...
Old Feb 20, 2017 | 04:09 PM
Dv8er's Avatar
Default Wipers blades don't go down all the way...
Had the opportunity to drive in the rain last night - first time since owning my LR3. I noticed that after I shut the wipers off, they did not retract all the way down. Is this a common problem? Is it the relay?
Thanks!
Old Feb 20, 2017 | 05:14 PM
Coleroad's Avatar
Mine is slightly lower but not by much, maybe an inch.
Old Feb 21, 2017 | 12:48 AM
KMET's Avatar
Whomever replaced cowling didn't reattach wipers properly. Carefully remove them, then move down.
Old Feb 21, 2017 | 12:26 PM
nevillusa's Avatar
Related to this, when we had some heavy ice recently, I accidentally turned on the Wipers without realizing they were quite frozen to the windscreen, and it caused my Driver Side Wiper to become disconnected from the metal arm, and also it must have 'dislodged' or 'moved' the spindle-connection area, because when I reattached the wiper blade, it was not sitting in the right place. I probably did a silly thing to fix it - I just 'turned' it by hand, so that the wiper blade sat in the right place. Perhaps I damaged something, although the wipers are working perfectly ok, even on full speed in heavy rain. I suppose I should probably examine closer, (when it gets warmer) to see if I did any damage by just 'turning' (instead of raising / removing / lifting, and then re-attaching in a slightly different place).
Old Feb 26, 2017 | 09:11 PM
Dv8er's Avatar
I'm going to get to the wipers this week - pull them off and reposition them while I have it in the shop doing the front hubs...and the tranny pan conversion...in my spare time!
acamato
Oct 18, 2013 10:22 AM
Muskrat37
Jun 18, 2012 09:12 PM
yellow24
Nov 7, 2011 08:16 PM
twaszak
Aug 1, 2011 09:14 AM
avking
Jan 16, 2009 05:44 AM
