2012 LR4, electrical issue. Dash go blank while driving.
Old Sep 29, 2019 | 11:43 AM
wehtjns's Avatar
4th Gear
Default 2012 LR4, electrical issue. Dash go blank while driving.
So this has happened a few times, but this morning was the worst.
This is my wife's car, 2012 LR4 5.0 we have owned it for about 3 years. It started about a year ago but has occurred now maybe four times. We installed a newer Interstate battery from LR about a year ago, I've checked the battery voltages and they are right on the money, I'll post numbers later. I've checked all the battery connections that I can think of to make sure they are tight.
It has been super dry here in Atlanta, FYI.
It usually just occurs at random; while driving, at a red light, etc. But this morning was the first time it has occurred while starting the car.
The tire pressure, temp gauge, AC are the first things to go out. Then the AC will stop flowing air, aka the blower, and then the entire dash goes out. The car still seems to drive normally, and no dimming of the headlights have been noticed. And then within 10-30 seconds, everything just restarts as normal.
This morning:
so the first video from today
the electrical issue at a red light, and AC is off
completely dark dash at night
TPMS light on, stereo and HVAC off.
I do own the Gap-II tool, but I'm very new at using it. The wife is currently at work with the car. About a month ago we took the car to the dealer, and they were unable to find any issue or replicate the issue. It will likely go back in the morning, as the wife is starting to feel uncomfortable driving it.
Any thoughts?, anything I can scan with GAP?
Thanks,
Nathan
This is the data/errors I just scanned from the computer with my GAP scanner
VIN: SALAK2D40CA619731
L319 - LR4 2012
Vehicle scanned on 29-09-2019 12:31
Using IIDTool BT V3.0 B2624
ACM-Audio System
  • U2200-41 (2C) Control module configuration memory is corrupt - System internal failure - general checksum failure
BCM-Body Control
  • B102B-87 (28) Passive key - Bus signal/message failure - missing a message
    ( on 29-09-2019 06:10:07 at 127562 km )
  • B1B01-87 (28) Key transponder - Bus signal/message failure - missing a message
    ( on 29-09-2019 06:10:16 at 127562 km )
  • U0155-00 (28) Lost communication with instrument cluster control module
    ( on 29-09-2019 06:09:04 )
  • U0164-00 (28) Lost communication with heating ventilation and air conditioning control module
    ( on 29-09-2019 06:09:01 )
  • U0184-00 (28) Lost communication with audio unit
    ( on 29-09-2019 06:07:15 )
  • U0214-00 (28) Lost communication with the remote function actuation
  • U0199-00 (28) Lost communication with the door control module A
    ( on 29-09-2019 06:08:50 at 127561 km )
  • U0200-00 (28) Lost communication with the door control module B
    ( on 29-09-2019 06:08:59 at 127561 km )
  • U0208-00 (28) Lost communication with the seat control module A
    ( on 29-09-2019 06:09:00 at 127561 km )
  • U025D-00 (28) Lost communication with front controls interface module B
  • U0010-88 (28) Medium speed CAN communication bus - Bus signal/message failure - bus is off
    ( on 29-09-2019 06:09:06 )
  • U0018-00 (28) Medium speed CAN communication bus (–) shorted to bus (+)
    ( on 29-09-2019 06:09:43 )
DSM-Driver Seat
  • U0140-00 (28) Lost communication with body control module
    ( on 13-09-2019 13:14:40 at 126487 km )
    ( on 13-09-2019 13:14:04 at 126487 km )
FCDIM-Front Control
  • U0010-00 (28) Medium speed CAN communication bus
    ( on 28-09-2019 15:24:53 at 127561 km )
    ( on 29-09-2019 06:07:14 )
  • U0300-00 (28) Internal control module software incompatibility
    ( on 21-10-2025 12:19:49 at 0 km )
  • B1D21-13 (28) Remote control switch - General electrical failure - circuit open
    ( on 15-09-2019 16:34:27 at 126613 km )
FCIM-HVAC Buttons
    ( on 29-09-2019 06:05:47 )
    ( on 13-09-2019 13:14:49 at 126487 km )
  • U0424-68 (28) Invalid data received from heating, ventilation and air conditioning control module - Algorithm based failure - event information
HVAC-Ventilation
    ( on 13-09-2019 13:14:35 at 126487 km )
  • U0140-87 (28) Lost communication with body control module - Bus signal/message failure - missing a message
    ( on 29-09-2019 06:05:33 at 127561 km )
IPC-Instrument Pack
    ( on 29-09-2019 06:07:04 at 127561 km )
    ( on 29-09-2019 06:05:03 at 127561 km )
  • U3000-87 (28) Control module - Bus signal/message failure - missing a message
KVM-Keyless
    ( on 26-09-2019 08:57:26 at 127405 km )
Old Sep 30, 2019 | 07:03 PM
LR Techniker's Avatar
Its really difficult to diagnose something like this over the internet. Heck, its hard to diagnose these issues when the car is in the shop. Without being able to read live data or look at the control module tree when its acting up, I can't tell if the Central Junction Box (CJB) is dropping Terminal 15 (T15) Circuits (see that a bunch on the Jaguar XF/XJ) or if you simply have a CAN Bus shutting down.
Because CJBs are common, it wouldn't surprise me if they recommend one, even if they can't confirm it.
Old Sep 30, 2019 | 07:32 PM
wehtjns's Avatar
4th Gear
Thank your for your reply. Yeah I would imagine this is going to be a pain to diagnose without having the symptoms occurring while all the computers are hooked up. The last time this occurred, around 4 months ago, the dealer was unable to find or replicate the symptoms after a week of testing. But thankfully my wife has learned now to record any episodes and resulting symptoms / variables.
the car is going back to the dealer next Wednesday for another round of testing. As that is when the next available loaner vehicle was available for a running issues / drivable issue.
I’ll report back the findings.
Old Feb 29, 2020 | 09:46 AM
rally1's Avatar
What was the result? I have the same thing on a 2015, happened a year ago, went away on the drive for repair, but back last night. I’m sure it will magically work when I drop it off.
Also the car wont restart without holding the key under the steering column.
Old Feb 29, 2020 | 10:44 AM
rally1's Avatar
Default My faults
L319 - LR4 2015
Vehicle scanned on 29-02-2020 08:09
Using IIDTool BT V3.0 B2643
BCM-Body Control
  • B102B-87 (2F) Passive key - Bus signal/message failure - missing a message
    ( on 28-02-2020 20:53:50 )
  • U0241-00 (28) Lost communication with the headlamp control module A
    ( on 28-02-2020 20:56:06 )
    ( on 28-02-2020 20:42:18 )
  • U0164-00 (6C) Lost communication with heating ventilation and air conditioning control module
  • U0184-00 (6C) Lost communication with audio unit
  • U0214-00 (6C) Lost communication with the remote function actuation
  • U0199-00 (6C) Lost communication with the door control module A
  • U0200-00 (6C) Lost communication with the door control module B
  • U0208-00 (6C) Lost communication with the seat control module A
  • U025D-00 (6C) Lost communication with front controls interface module B
  • U0010-88 (2F) Medium speed CAN communication bus - Bus signal/message failure - bus is off
    ( on 28-02-2020 20:42:19 )
GWM-Gateway module
  • P065C-01 (2C) Generator mechanical performance - General failure information - general electrical failure
    ( on 28-02-2020 20:54:07 )
  • B1412-96 (2F) Quiescent relay box - Component failure - internal failure
    ( on 06-02-2020 16:59:50 at 101914 km )
IPC-Instrument Pack
  • U0102-00 (68) Lost communication with transfer case control module
  • U0121-00 (68) Lost communication with ABS control module
    ( on 24-02-2020 10:43:12 at 102533 km )
  • U0136-00 (6C) Lost communication with differential control module - rear
  • U0138-00 (68) Lost communication with all terrain control module
  • U0140-00 (6C) Lost communication with body control module
  • U0151-00 (68) Lost communication with restraints control module
    ( on 28-02-2020 20:42:17 at 102918 km )
  • U0241-00 (6C) Lost communication with the headlamp control module A
    ( on 06-02-2020 16:51:18 at 101914 km )
  • U0242-00 (6C) Lost communication with the headlamp control module B
  • U0264-00 (6C) Lost communication with the rear camera module
    ( on 06-02-2020 16:50:43 at 101914 km )
  • U3000-87 (2F) Control module - Bus signal/message failure - missing a message
PCM-Engine Petrol
TCM-Transmission 8spd
  • B1087-63 (28) LIN bus A - Algorithm based failure - circuit/component protection time out
    ( on 24-02-2020 10:43:11 at 102533 km )
- from mobile -
Old Feb 29, 2020 | 12:46 PM
boothannie's Avatar
I know you said your battery is testing fine, but have your considered switching your battery out? This happened to my 2011 LR4. I had just bought the battery 11 months earlier from Advance Auto. The battery tested fine, but Advance said every so often a battery will test fine but still be defective. They went ahead and replaced it for free and it has been 6 months and hasn't happened again. Not sure if it was happening with both your old and new battery, but might be worth it. Could have completely been a fluke with mine. Good luck!
Old Feb 29, 2020 | 01:14 PM
rally1's Avatar
In my case I am on a new battery and alternator.
Old Mar 18, 2020 | 08:36 PM
rally1's Avatar
OP didn't respond, but in our case dealer replaced the Quiescent Module. LR038721 LR056084 for anyone else has the issue.
Old Jun 19, 2020 | 09:33 AM
Adeuk's Avatar
6th Gear
Hi, after searching all over the global network, I have finally found a match for the faults on my Discovery 4 (I'm in the UK)
As this has so far foiled a few garages/specialists, I wonder if the OP (Nathan) would be able to confirm what was required to fix his car.
Rally1's diagnosis is helpful but did not exactly match my issues and his repairs have already been ruled out for my car
Many thanks in advance
Ade
Old Jun 19, 2020 | 09:54 AM
Adeuk's Avatar
6th Gear
Hi, I am so pleased that after hunting the entire global internet, I have finally found an exact match with those of the OP for the faults on my Discovery 4 (I am in the UK)
Although I note Rally1's reply, his faults are not quite the same and have already been ruled out.
Nathan, I wonder if you would please be able to confirm the final diagnosis as this has so far stumped by garage and a specialist diagnostics firm, although they do believe that it is current/voltage related.
Thanks in anticipation
Ade
