2015 LR4 rear drivers speed sensor p2159-02
I am trying to find where the speed sensor wires run as I replaced both rear sensors and still have the code showing after clearing. The fuel level works have been diverted due to snapping at the connector on the same side but I do not see the speed sensor cable going to the same big connector. I need to trace the wire but am having a difficult time following the path. I have an iid tool which shows it is an open or short on left rear sensor causing the three amigos. Any help or suggestions welcome
user440
08-17-2019 08:38 PM
