255/65/r19 tyres on a LR4
Old Apr 30, 2023 | 12:49 PM
Chesby's Avatar
Default 255/65/r19 tyres on a LR4
Hi. Need new rubbber and wheels. I have heard conflicting things about people fitting the big Conti 65/19 tyres that come stock on the New Defender onto a D4. Like the front may rub. If it drops to bump stops it will completely drop onto the rubber (which sounds kinda dangerous at speed). I have had a bad compressor on one car but it never dropped me suddenly onto the bump stops. Is that possible? If so I’ll stick with a 55 or 60 tyre wall (60/19s are so hard to find though - if anyone has a recommendation for a soft riding all season tyre Lmk!) cheers.
Old Jul 4, 2023 | 04:26 PM
superantew's Avatar
8th Gear
No maximum is 255/60r19 and then u have no rub and can fit in sparewheel under trunk.
General grabber at3 was my choice of tyre- very quite
Old Jul 7, 2023 | 06:42 AM
guy's Avatar
guy
my $0.02 worth. Yeah… about the situation “if the air suspension fails”…
I know it has happened to some. But it is very robust and if you keep up your inspections after having fun…
Moreover, you can always keep spare blocks to add to the stop blocks in the event of failure.
I suppose I am less risk adverse then some others.
As I purposely significantly deflate the tires for off road; oversized tires work for me.
Yes, Then pump them up again for the road.
No issues yet…
Old Jul 20, 2023 | 10:48 AM
Nechaken's Avatar
4wd High
Unless you want to cut the frame horns, you'll need to keep the tire diameter to about 31.5, 31.6 inches. 255/65/19 will be a bit over 32" . If you don't want to switch to 18" wheels, I'd keep to 255/60/19 to get a little bump in sidewalls.
Old Jul 20, 2023 | 04:56 PM
superantew's Avatar
8th Gear
Yes thank u ur absolutely right about the size that fits.. 255/65r19 did not fit
I went for 255/60r19 general grabber and are super happy the spare wheel even fits under the trunk with 255/60
18" rims I've heard that it doesn't fit at least on the sdv6 because of brake rotors/calipers.. so we are pretty much stuck with 19" on the discovery 4 without serious mods..
Thanks for reply
segulex5
LR4
Apr 2, 2021 09:11 PM
JUHSTin
LR4
Aug 23, 2019 06:18 AM
ToRoveOrNotToRove
LR4
Jun 27, 2018 09:13 PM
illbenooneelse
LR4
Dec 19, 2017 11:31 AM
dngvt
Tires
Mar 25, 2016 06:35 PM
