Air suspension "adjustments"
Old Mar 7, 2013 | 10:02 AM
Orkney LR4's Avatar
Default Air suspension "adjustments"
Is it normal for the air suspension to make "self-adjustments" without selecting off-road or access height?
When I shut the vehicle off it seems to lower the back corner a little. Also, when the car is just idling, it will make little adjustments.
Is this normal?
Old Mar 7, 2013 | 02:13 PM
HeliRy's Avatar
Yup, that's all fine. As far as I know (someone correct me if I'm wrong) these adjustments are made as the weight of the vehicle changes. This keeps it at a constant per-set height no matter how many people/cargo/fuel is being carried. When you shut it off and get out, it senses it's a little lighter and so it brings the ride height down a tiny bit. Same when the vehicle is at idle or even in motion, it tracks the slight movements and weight changes and adjusts accordingly.
Old Mar 11, 2013 | 11:52 AM
bates's Avatar
ditto^^
TRIARII
Jun 30, 2022 09:48 AM
jycsalas
May 23, 2019 03:02 PM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
Disco2Fever
Dec 21, 2011 02:59 PM
