anti freeze odor
It depends on where it is coming from, which will determine the best place to examine. If its leaking under the supercharger, you have a small window to peep through, next to the throttle body, at an angle under the supercharger. If its leaking, you should see a puddle collecting.
Sometimes you can see the water pump leaking by removing the air intake tube and using a mirror, but be carefull, if its leaking under the supercharger, it will run down the front of the block behind the water pump, making it look like the pump is leaking.
Hoses and thermostat should be obvious as is, or at least with air intake removed.
leak
ok got stuff off the top part and pressurized again drip drip is ending up coming down behind the crank pulley....... cant see a leak coming from water pump with mirror and light also on top off the thermostat hose is a grey y coming from top of expansion tank and hose that runs across the top of the radiator one end is open i ran a wire in and i doesnt seem to be blocked off.......... where to go from here i can pull fan pully and belt and pressuise again?thanks
