anti freeze odor
Old Dec 1, 2019 | 03:51 PM
Celto 4's Avatar
Default anti freeze odor
we purchased a 2015 LR4 a couple of months back today after returning from a short 50 mile trip i noticed an ant freeze odor not dripping on the ground but appears to be a slight amount in the pan anything nprone to going on these 60K Thanks
Old Dec 1, 2019 | 05:03 PM
LR Techniker's Avatar
Coolant pipe under the supercharger, water pump, thermostat housing and occasionally some of the random smaller coolant pipes (i.e. from expansion tank). They are all plastic now and do not age well.
Old Dec 1, 2019 | 11:53 PM
ColoLR's Avatar
We had all of ours replaced chasing the same minor leaks prior to 50k.
Old Dec 2, 2019 | 08:27 AM
Celto 4's Avatar
Default anti freeze type
i am in a spin i know dont mix colors but what does everyone use
Old Dec 7, 2019 | 12:11 PM
Celto 4's Avatar
Default af leak
hi all ok i got a pressure tester and brought system up to 15 psi as per service bulletin................got much more dripping and leaking than when running ...so im guessing to get a better visual ill have to pull fan ect as opposed to bottom pan ?thanks
Old Dec 7, 2019 | 01:36 PM
It depends on where it is coming from, which will determine the best place to examine. If its leaking under the supercharger, you have a small window to peep through, next to the throttle body, at an angle under the supercharger. If its leaking, you should see a puddle collecting.
Sometimes you can see the water pump leaking by removing the air intake tube and using a mirror, but be carefull, if its leaking under the supercharger, it will run down the front of the block behind the water pump, making it look like the pump is leaking.
Hoses and thermostat should be obvious as is, or at least with air intake removed.
Old Dec 7, 2019 | 01:47 PM
Celto 4's Avatar
Thanks moving slow im an old series and disco guy looks like a jungle in there to me
Old Dec 7, 2019 | 03:00 PM
Celto 4's Avatar
been an hour trying to get that sqeeze fitting off have tried all around it im guessing its to press on the ribbed part as usual ant tips
Old Dec 7, 2019 | 03:21 PM
Celto 4's Avatar
yup duh moment took off another one and was pulling wrong way
Old Dec 8, 2019 | 12:33 PM
Celto 4's Avatar
Default leak
ok got stuff off the top part and pressurized again drip drip is ending up coming down behind the crank pulley....... cant see a leak coming from water pump with mirror and light also on top off the thermostat hose is a grey y coming from top of expansion tank and hose that runs across the top of the radiator one end is open i ran a wire in and i doesnt seem to be blocked off.......... where to go from here i can pull fan pully and belt and pressuise again?thanks
