Battery/BMS, EPB & CanBUS issues???
Old 04-28-2021 | 10:35 AM
jlglr4's Avatar
Sorry to hear you are still struggling with this, but I thought this link might be a good resource for you if you are concerned with current drain: https://www.disco4.com/forum/topic119574.html.
  #22
Old 05-24-2021 | 03:23 PM
jahummer's Avatar
So, after several more MIL issues related to EPB, CANbus and fueling, I decided to try an experiment, I disconnected the console EPB harness, the EPB harness at the actuator and the DTML pump. I sprayed them thoroughly with electronics cleaner and put them back together. I've since over the last 4 weeks had no further DTCs related to the EPB, though replacing the alternator, at least for some time, also appeared to eliminate errors. Additionally another issue seems, at least mostly, to have been resolved with regards to too low idle RPM.
PeetzLR3
12-11-2023 11:21 PM
hshamamian
LR4
01-20-2020 03:30 PM
sean2k
02-02-2010 05:01 AM
2000 Disco 2 SD7
01-25-2009 02:59 PM
hanivw
02-09-2008 10:35 PM
Quick Reply: Battery/BMS, EPB & CanBUS issues???
