Bleed rear climate heater lines
Old Feb 28, 2023 | 05:40 PM
jahummer's Avatar
Default Bleed rear climate heater lines
I have changed many engine cooling hoses and tubes myself over the past few years. Recently fitted water pump number 3 (looks like it was actually a failed o-ring on the rear outlet tube). Compared to previous experiences had a hard time bleeding air despite not loosing that much coolant and ended up having to vacuum the system via the expansion tank. A few weeks later whilst trouble shooting air con issues, I discovered the rear climate does not blow hot even at max heat. Checked heater lines and they appear to be cold instead of hot which leads me to think there must be air in the rear lines. Workshop manual does mention anything about bleeding the rear lines.
Anyone here have any suggestions?
Old Mar 2, 2023 | 04:57 AM
jahummer's Avatar
Solved, I think. Raised front of the truck at 45 degrees and bled the engine compartment rear heater line. Rear climate lines now hot.
Stevie Sanchez
Feb 7, 2021 04:16 PM
04duxlr
Jan 13, 2017 07:58 PM
CaptainCulp
Dec 12, 2014 03:02 PM
killerpav
Sep 1, 2014 11:14 PM
jalodge
Apr 30, 2014 02:47 PM
