Car accelerates by its own
Old Oct 25, 2021 | 12:06 AM
RicVTE's Avatar
7th Gear
Default Car accelerates by its own
Hello, I am new here, it is nice meeting you.
I have an LR Disco 4, 3L TD, build year 2015. Over the last years I was very happy with it, just sent it recently for general check-up and maintenance, had the batterie changed as that light was on for some time, and all the regular check ups, oil-change etc.
The mechanic just finishes and goes for a test drive and suddenly standing at a junction, the car starts revs up to 8-9 K RPM just by itself. The following days the car did it again. I have read here in the forum that some people have experienced that with D3s. According my mechanic the external computer shows that a fuel injector is defaulting.
Has anybody had the same problem and if so, what was the remedy? Thank you all for your input.
Best regards
Old Oct 27, 2021 | 10:30 AM
BoeingBoeing's Avatar
I just went through this on mine. On start up it would rev into the stratosphere. Turned out to be a cracked passenger side valve cover causing an air leak. Check engine light on with codes for Lean Bank 1 and Lean Bank 2 showing.
Old Oct 27, 2021 | 09:21 PM
RicVTE's Avatar
7th Gear
Dear Boeing Boieng,
Thank you very much for your reply. I will forward the information on to the mechanic and hope it solves the problem.
have a nice day
Ric
Old Nov 5, 2021 | 10:38 PM
RicVTE's Avatar
7th Gear
Hello,
I just want to check with other kind members of this forum, did nobody else have that same problem? My mechanic is still working on the car.
Thank you in advance for your ideas and comments
AndrewStf18
Range Rover L405 (Fourth Gen)
Aug 24, 2021 01:36 PM
Tommy Zandi
Feb 19, 2021 01:10 AM
wastesandpines
May 6, 2014 09:35 AM
skylinegtr
Nov 14, 2006 07:17 AM
windyday
Freelander
Sep 11, 2006 09:31 AM
