Code P0019-Crankshaft Position
Old Jan 28, 2020 | 04:48 PM
Wilybyrd's Avatar
Default Code P0019-Crankshaft Position
2010 LR4 went into restricted performance and gave code P0019- Camshaft position, bank B error. What are possible causes of this? I'm hoping this isn't a timing chain issue. No loss of coolant or oil.
Wilybyrd
'10 LR4 HSE
Old Jan 31, 2020 | 06:30 PM
LR Techniker's Avatar
More than likely a timing chain issue. The chain stretches and the tensioners collapse, allowing cams to jump time. You can pull the oil fill cap off and take a look at the chain. We use a long hook to tug on the chain. If its loose and sloppy, then you have your answer.
Old Mar 11, 2020 | 02:20 PM
Wilybyrd's Avatar
To close out this thread with a definitive answer, it was a timing issue, but not one of the usual failure points (from what I read here). The tensioner had become loose, changing its point of engagement on the guide, causing it to jump time. Went ahead and had my indy shop do the full service of changing all guides, chains and tensioners as at that point with the labor the parts are hardly the big expense.
Wilybyrd
'10 LR4 HSE
CB7010
LR4
19
Nov 17, 2022 10:11 PM
LeakyDisco
LR4
Jan 23, 2019 02:31 PM
teklord99
Dec 3, 2018 02:48 PM
rltw
LR4
May 16, 2017 09:40 AM
DeepBlueWater
Oct 20, 2011 06:27 AM
