Engine Fault Codes
Old Apr 16, 2021 | 03:49 PM
SC Rover's Avatar
Default Engine Fault Codes
Just finished a head gasket and timing chain job on my 2010 LR4, and got a couple codes when I fired it back up. Apparently she needs coolant temp sensors now, whatever. But I'm confused by a P0662 and P0562.
The service manual just says
P0662 : Manifold Valve Output Drive 1 : Short Circuit to Battery
and doesn't even list P0526 but my code scanner says "Fan Speed Sensor Ckt"
Any thoughts on where to start with these would be a huge help, cuz I got nothin' right now.
Thanks!
Old Apr 18, 2021 | 07:37 PM
SC Rover's Avatar
For anyone searching these codes in the future, apparently changing out the engine coolant temp sensors will keep those from coming back.
Old Apr 18, 2021 | 08:01 PM
jlglr4's Avatar
Good to know. Did you change out both temp sensors, or only one? If only one, please let us know which one.
Thanks.
Old Apr 18, 2021 | 09:45 PM
SC Rover's Avatar
I changed both, but not for any good reason. I just couldn’t figure out which sensor was “bank 1” from a P0117 code.
Old Sep 12, 2022 | 08:04 PM
DallasLoneStar's Avatar
Hey guys, I have a coolant temp sensor code but cannot find how to change it anywhere. And apparently there are two? Any advice?
Old Sep 12, 2022 | 09:54 PM
SC Rover's Avatar
There is one temp sensor on the back side of the crossover pipe between the two heads on the back side of the engine (above trans) - won’t leak coolant too terrible bad when you take it out. The other is on the coolant hose below the thermostat - behind the fan, follow the wiring cuz it the only wiring that come from the top of the engine and plunges straight down the front of the engine. This one will leak a lot of coolant. Imagine that scene from Raiders of the Lost Ark where Indie quickly swaps the gold idol for the bag of sand - it will be like that except with temp sensors.
the sensors themselves have a little tab on them that you’ll pull back on and they twist out a quarter or third turn
Old Sep 12, 2022 | 10:09 PM
@SC Rover sounds like the front one can be gotten to. Is the top one inside the intake cover? Any way to tell with IID which one is causing the code? Thanks for the help!
Old Sep 12, 2022 | 10:18 PM
SC Rover's Avatar
If you’re getting a fault code, it should tell you bank one or bank two - unfortunately, I never figured out which was which and just replaced both.
Start with the front cuz it’s easier and go from there I guess…
You can get to the back one just by removing the pretty noise cover on top, but it sucks and your get some annoying scratches on your forearms reaching back there. If you look behind the air plenum (or SC if SCV6…) you’ll see a bundle of wiring and below that is crossover tube. Sensor is on the back side of that closer to the passenger side of the vehicle before the tube turns and plunges down into the head connection. .
Old Sep 13, 2022 | 09:25 AM
@SC Rover ok thanks. I think last question: according to pics of the part, these have a hex on them but no threads… are they just pull out, push in? And both are the same part?
Old Sep 14, 2022 | 10:30 AM
SC Rover's Avatar
Yes, both sensors are the same part.
See attached pic. The tab opposite the connector will pull back away from the business end of the sensor, then you’ll twist (standard right hand thread) a quarter turn and pull the sensor straight out. If you look about halfway between the lock tab and the connector, you can see a little box channel that acts as the female thread.
Pay attention to the connector orientation as it’s seated now, and where it stops when you twist it to remove. There is only one way that this sensor can be installed, and trying to figure out that orientation with fluid pouring out can throw your focus.
ScottPNW
LR4
Feb 18, 2019 08:28 PM
03discoman
Sep 2, 2009 04:32 AM
timothyfuqua
Feb 13, 2008 03:22 PM
rgreenwell8962
Oct 12, 2007 09:13 PM
izzy
Feb 27, 2005 10:43 PM
