Every electrical error known to man 5.0 LR4
Old Jun 1, 2024 | 05:35 PM
Noah Woodcock's Avatar
Default Every electrical error known to man 5.0 LR4
I replaced my alternator and battery and drove for 2 days, this morning car doesn't run and I get all of these errors. I cleaned/reseated the connectors on the ECU and TCM. Is the ECU shot? What is going on? Battery and alternator both tested as good and the car goes into accessory mode no problem.
Old Jun 1, 2024 | 05:41 PM
TheFixer's Avatar
Battery coded properly?
Check all connections to make sure nothing loose?
Ground is good?
Battery drain?
So many things can make that happen.
Old Jun 1, 2024 | 05:45 PM
Ground is good?
Battery drain?
used my gap tool to reset after battery install.
Everything is connected well
The errors appear instantly when starting on a fully charged brand new battery.
Ground would be the only thing. Do you know how to check on the LR4s?
Old Jun 6, 2024 | 03:55 PM
guy's Avatar
guy
Humor me, after resting overnight and without starting the engine, what is the battery voltage…
(not through odb)
If you are less than 12.6…
landy2023
LR4
Jan 24, 2024 05:59 AM
gaz_0001
LR4
Nov 20, 2020 03:56 PM
churious
LR4
Feb 13, 2017 07:04 PM
Herdfan
Jun 21, 2016 02:54 PM
Manito
Mar 28, 2016 06:25 PM
