Help!! Should I buy this LR4?
Old Mar 30, 2023 | 11:46 PM
Mowing4x4's Avatar
5th Gear
Question Help!! Should I buy this LR4?
Should I be worried about all this rust? It's a 2015 with 65k miles that I may buy tomorrow in the high $20k range...
I need to make a decision in the next couple days on whether to buy this thing, or not! It would be my first Land Rover, so I kinda need some help understanding what I'm getting myself into. Is this rust as bad as it looks, and should I walk away from this purchase? Open to hearing if you think this is (reasonably) repairable.
Thanks for your help everyone!!
File Type: mov
Old Mar 30, 2023 | 11:49 PM
Mowing4x4's Avatar
5th Gear
(Vieo is also attached)
Old Mar 31, 2023 | 07:21 AM
ugmw177's Avatar
the lower A arms are replaceable in fact the bushings are probably worn and need replacement anyhow. The rust on the chassis welds is more concerning. Probably needs closer inspection and if you buy, clean and treat with rust converter or POR type sealer. Also I would remove the rear bumper cover hitch cover and check for rust on the rear crossmember...Looks like it lived in a road salt area for a while
Old Apr 1, 2023 | 09:28 AM
jahummer's Avatar
Since this's your first time venturing into Land Rover ownership, I'd highly advise researching the requirements for keeping these machines alive, it's not for the faint of heart. I'd also be concerned about the amount of rust on this one. Mine's done 150K miles and no rust whatsoever, anywhere.
Old Apr 2, 2023 | 08:30 PM
Mowing4x4's Avatar
5th Gear
I appreciate your feedback! This is a 2015 LUX Package w/ HD Pkg as well! I did receive a few additional pictures this week and will be sending the car to a shop for a pre purchase inspection tomorrow.
These new pics show rust in a few other areas... also one of the suspension (rubber sleeves.. I think that's what it is?) looks all bent out of shape. Please give me a shout if this looks worse than I'm thinking it is.
Cheers!
Old Apr 3, 2023 | 07:14 AM
guy's Avatar
guy
I live in a road salt zone. And none of my cars look like that.
A bargain… usually manifests itself with many very expensive repair bills.
Old Apr 12, 2023 | 07:07 PM
pagoda's Avatar
I guess you passed on this. There's nothing in those pictures that would worry me in the slightest - perfectly normal surface rust that I've seen on all of my 10+ LR3 and LR4. That's not to say there isn't rust in places you should be concerned about, however. You should check the air reservoir on the underside; the mounts and the tank, especially the welds at the ends. If the vehicle has OEM side steps, check the sills as they could be very ugly.
Old May 4, 2023 | 02:57 PM
mmbirtcher's Avatar
I agree with @pagoda on the rust although difficult to really tell from pics. Mine started its life in Cincinnati and has some rust but all surface. I keep it clean and garaged now. Better than a Toyota, 😆 which are notoriously rusty.
marginroadtrip
LR4
Jun 2, 2024 10:56 AM
ButchNeedsCoffee
LR4
Jan 16, 2023 06:26 AM
havefundogood
LR4
Mar 11, 2022 06:43 AM
Al Pinter
LR4
Apr 17, 2021 10:21 AM
gaz_0001
LR4
Nov 20, 2020 03:56 PM
