High Beam Problem
Old Nov 14, 2025 | 05:32 PM
IluvRovers's Avatar
Default High Beam Problem
Hello, I just came home from a mechanic who replaced my PVC valve on my LR4 2016, due to two vacuum codes that were thrown. Anyway, on the way home I was not able to use my high beam lights. The arm switched on, but the high beams did not come on, however the flash part of the high beams worked. Everything worked fine last night. Is it possible that a connection was detached when they replaced the PVC valve. To get to the valve, they had to detach many components. Thanks for your help.
ReignRock
Oct 23, 2023 09:24 AM
ahab
Feb 5, 2021 09:44 AM
andrewhalliday
LR4
Jun 27, 2016 10:04 AM
LR4LIFE
Nov 6, 2007 10:23 PM
