How to use VIN to see build sheet?
Old Apr 6, 2021 | 06:47 PM
ljdiscovery's Avatar
Default How to use VIN to see build sheet?
Is there a way to use a VIN to see how a vehicle is outfitted? I am looking at a 2014 LR4 HSE, not sure if it is a LUX or not and whether it has the high low transfer case. thanks Phil
Old Apr 6, 2021 | 07:16 PM
jlglr4's Avatar
Used to be able to use the land rover Topix site, but I heard they’ve removed that functionality. If you have pictures of the interior, you can look for the high/low transfer case button in the center control panel. I circled the area in the below pic. If that circled button is blank - no HD package (no high/low, no locking rear diff). I found this to be the easiest and fastest way to check. This only applies to model year 2014 onward.
Old Apr 6, 2021 | 09:45 PM
salpiner's Avatar
4th Gear
This is the most extensive site I've found.
Complete build sheet!
https://www.vindecoderz.com
Old Apr 6, 2021 | 10:57 PM
great vin decoding site thank you. the photo was helpful. button is blank. vin code says it has an open rear diff. thanks Phil
Old Apr 15, 2021 | 01:13 PM
nevillusa's Avatar
Yes !! Vindecoderz is excellent - And FREE. I would never purchase an LR3 or an LR4 without checking this, due to the 'mystery' surrounding exactly which version the vehicle is (Lux or not), and exactly what additional Options are fitted, or not. Case in point, I looked at an LR4 a month or so ago, the place selling it insisted it was a Lux, but it clearly was not, based on Vindecoderz.
Old Nov 11, 2023 | 01:16 PM
Mr.Twister's Avatar
I use https://vin-spec.com to get full build sheet, it's much cheaper and has a lot more information in the build sheet.
readrover
LR4
Dec 8, 2020 12:23 PM
NoVARova
Feb 1, 2019 12:37 PM
Mwinget
LR4
Dec 24, 2015 08:09 PM
srg.one3
Jan 17, 2015 03:33 AM
LRnewbie12
LR4
Jan 6, 2013 06:45 PM
