Ignition goes off when trying to start
Old Jan 11, 2021 | 01:01 PM
stoksu's Avatar
3rd Gear
Default Ignition goes off when trying to start
Hi folks
Have anybody had an issue with ignition start button? When I press start button without brake (dash lights go on) and then press the brake and press start button again engine will not crank and all the dash lights go off. And when ignition is off I press the brake and then start button all it does it turns ignition on for about 2 secs and then ignition goes back off again. I've managed to start the car by shorting starter motor relay and this is the only way to start the car. Start button replaced, did not help. Any ideas? Thanks
Old Jan 11, 2021 | 01:53 PM
pagoda's Avatar
If you've started it shorting the starter motor relay presumably you've ruled out all the obvious stuff like earth connections, both batteries, etc. Have you read the faults?
Old Jan 11, 2021 | 02:30 PM
stoksu's Avatar
3rd Gear
BCM: Invalid signal from ABS Module and Lost communication with Parking Brake Module. Would any of these two not allow engine to start? No faults in ECU or TCM. I've also checked brake pedal switch works fine.
Old Nov 15, 2021 | 04:30 PM
wilber1978's Avatar
hi did you work out what the problem was my discovery 4 is doing the exact same thing now
Old Nov 16, 2021 | 01:23 AM
stoksu's Avatar
3rd Gear
yes mate, it was abs pump that does not allow to start if break fluid has not reached correct pressure. I was doing it after lifting the body and all breakes were still disconnected. Ive connected all break pipes bled them up and car started without any issues. Hope this helps in your case
Raf
Old Nov 16, 2021 | 01:38 AM
wilber1978's Avatar
Raf
Ah yes that will solve it. I just replaced a broken crank and had body off Also. All brakes are plumbed in but have not blead them yet. Great to know. I was expecting it to be the brake switch on the pedal. Couldn't see anything else on the schematic. Thanks for your reply. 👍
Old Oct 1, 2022 | 10:17 PM
Resk8's Avatar
Im getting the same issue with my 2017 disco 5. I had replaced my telematics backup battery and after that the disco will do exactly the behavior describe by the OP. I not sure but i physically unplugged the telematics module from the car to replace the backup battery and now im guessing some configuration got messed up. I have unplugged the main battery and same thing. I have also bought a brand new battery and still getting the same thing. Checked all the fused in the 3 fuse boxes and no issues found. Not sure what to try anymore. Im guessing that the telematics module disconnect and reconnect needs the dealer to reset the ****ing car to start up again? I tried pressing the break as hard as i could but no luck and i did not mess around with the breaks.
Any ideas? Did i fry something?
Old Nov 11, 2022 | 10:05 AM
Jab523's Avatar
Hi mate, did you manage to figure out a fix for this by any chance? I have a Range Rover sport L494 and facing the same issue, I changed the Telematics battery and since then it’s not starting?
Any help would be greatly appreciated!
Old May 18, 2023 | 10:19 PM
Hotjava69's Avatar
Default Fix
What ended up being the fix for this? I have the exact same problem on my 17 Range Rover.
Old Jul 24, 2023 | 04:51 PM
evoqueeq's Avatar
Default Fix?
Hi did anyone manage a fix for this same thing is happening with my 2016 evoque
