L319 & Brembo...
Old Jun 13, 2019 | 04:58 AM
iconoclast's Avatar
Default L319 & Brembo...
The Landmark I own is due for brakes soon and curious to know if there is an off the shelf "Brembo Kit" for all four corners or if the Range Rover Sport set up could be installed without issue on the LR4.
While this is mostly aesthetic I have never been a fan of the pedal feel either and I am hoping this would improve the looks and braking.
If anyone on here has any experience or opinion on this please share. Thank you.
Old Jun 13, 2019 | 07:59 AM
Oldman846's Avatar
I hope that this helps: https://www.landroverworld.org/threa...upgrade.30434/
I am doing the same swap on a '15 LUX. EBay has quite a few 06-09 RRS calipers. Partsgeek is out of stock, but here is a website with the part number for reman, centric caliper https://www.partsgeek.com/8plnn77-la...e-caliper.html
Unfortunately, I did not save the forum post where I got that part number. If you look at centric's application guide, you should be able to find the left-hand part number.
From what I understand through part numbers and other forums, the stock, LR4, rear brakes are the same as the RRS.
My part list included:
-06-09 RRS supercharged calipers
- 06-09 RRS front, brake wear sensor (SEM500090)
- EBC brake rotors and pads kit from lucky8 (06-09 RRS 4.2L supercharged) ---- https://www.lucky8llc.com/collection...-ebc-brake-kit
- LR4 rear brake sensor (SOE000025)
- beck and arnley front brake hardware (084-1810)
- britpart stainless brake line kit (bought from lucky8 via ebay)
- new caliper mounting bolts (VX68D8)
- Mike
Old Jun 13, 2019 | 11:31 AM
DakotaTravler's Avatar
This also might be of help, just passively posting cause I dont have an LR4 or RRS.
https://www.rangerovers.net/forum/9-...tml#post369359
Old Jun 13, 2019 | 04:57 PM
Oldman846's Avatar
Thank you, Dakota. That was the exact link where I found the part numbers, and i could not re-locate it. It also has the accurate description of the appropriate caliper, related to the harmonic weight orientation.
cybercop
LR4
Feb 15, 2019 02:52 PM
JUHSTin
Mar 31, 2014 01:28 PM
Orkney LR4
LR4
Dec 4, 2013 10:26 AM
rzuluaga
LR4
Nov 15, 2013 09:22 AM
LRFlatirons
LR4
Jul 29, 2010 11:16 AM
