Location of Nav unit in a 2012 LR4
Old Sep 17, 2018 | 05:30 PM
Rover1968's Avatar
4th Gear
Default Location of Nav unit in a 2012 LR4
Does anyone know where this unit is located? I need to check my connections to try and figure out why my gps is showing me 150 miles from where I actually am. Also, is the shark fin antenna on the top of the vehicle the satellite and gps antenna? It only has one yellow wire coming from it, and when I unplug it my satellite radio quits working so I am assuming the antenna is not my issue. For some reason, I can't find anything on this particular model of LR on the internet. I only noticed this problem this past weekend and it has only recently started, because it worked fine when I went to the beach 2 months ago.
Old Oct 1, 2018 | 06:22 PM
jaguardoc504's Avatar
The screen is the Nav unit.
It's all built into one unit.
Old Oct 3, 2018 | 09:45 AM
Rover1968's Avatar
4th Gear
Thanks for the reply. I have seen where some are mounted under the drivers seat.
Old Oct 5, 2018 | 08:06 AM
Geo's Avatar
Geo
Sounds like software issue as I believe GPS is digital.
I recall some radios were replaced or updated. You could try a hard reset of the computers by disconnecting the battery terminals and touching the positive and negative cables together with a short wire to completely discharge the system. Not the battery terminals, but the cables!
Old Oct 5, 2018 | 08:50 AM
Rover1968's Avatar
4th Gear
I ordered a gps antenna from Amazon with the Fakra-C connector on it which is the same as the connector on the oem antenna, connected it and after about 1 minute it corrected position and the gps is now working. Cost me about $10 instead of the $600 Land Rover quoted me. Only thing now is the TMC button still has the red line through it. I've read that you need to tune to a FM station that broadcasts the tmc signal, but I cant seem to find any info on stations in my area that broadcast it.
Rover1968
LR4
Sep 16, 2018 01:08 PM
RW707
Dec 14, 2013 04:40 PM
ultramike
Apr 10, 2006 04:53 PM
tropnevad
Feb 22, 2005 04:12 PM
